EM TuningAH Fabrications
Results 1 to 8 of 8
    Dec 2011
    manchester
    107
    opening the bonnet
    i believe my bonnet opening lever has had it when i pull the lever nothing.
    the lever it self is fine and the cable is still attached i have tried pulling the cable it self with a pair of pliers
    anyone else have ideas of how to get it too open
    looking for
    550cc injecters, tycosport fmic, k04 water and oil lines, S3 maf, badger tip,
    347
    347's Avatar
    Sep 2006
    223
    Get a can of wd40 or similar and point the spout into the bonnet where the catch is
    give it a proper soaking and leave for 10 mins ,
    then try your lever again .
    it worked for me a couple of years ago !
    2010 2.0 Tfsi BE ibis white DSG , now sharked
    Sportback owner
    Apr 2007
    France
    466
    Agree with '347'. After soaking with WD40, get someone to jiggle the bonnet up and down (takes the load off the mechanism) while you operate the release lever. Most likely that will fix it. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Aug 2010
    1,540
    if these are like mk5 golfs you can pop the vw badge out of the front grill and theres a little square hole you can put a screw driver in to pop the bonnet.
    kanecullen89's Avatar
    Jul 2009
    237
    How did you get on with this?
    I had the same problem last winter but my bonnet wouldn't shut properly (catch was stuck open). I just doused the mechanism under the bonnet and the cable with pit stop oil (free lubricant spray I got following an extortionate Audi cambelt service) and its worked fine ever since. I just give all the joints on the car a little spray every now and then to keep it smooth
    Dec 2011
    manchester
    107
    spayed it twice and left for 10 min after each time and nothing still shut
    looking for
    Sportback owner
    Apr 2007
    France
    466
    Where are you spraying? The release mechanism is not where the bonnet catch goes into the lock, but further to the driver's side (mine is a LHD so mine is to the right. You need to use a fairly long tube to get the oil to it.
    Jul 2011
    Hartlepool
    98
    Get somebody to put pressure on the bonnet whilst you operate the bonnet catch. Worked for my mrs, give it a try.
    Wanted:
    A3 8P Sline/S3 Rear Spoiler
  1. Quick question while the bonnet is open!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2011, 22:45
  2. Cleaning under the bonnet - best way?
    By VAGMAN1 in forum Detailing
    Last Post: 26th November 2006, 22:18
  3. strange noise when you open the drivers side door
    By MateloT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2004, 13:30
  4. wierd wine noise from under the bonnet
    By nervus in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2004, 10:47
  5. Anyone else get a river when they open the boot??
    By Irish in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2004, 11:43
