JMB RetrofitsAH Fabrications
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By mike foster
Thread: Help: A3 starting problem
    Sep 2012
    16
    First post and hope you guys can help me with a problem on my A3 Sept/2007 140 TDI DSG 53k miles.
    Parked the car today, engine warm, tried to start it and the engine ticked over once or twice and wouldn't start. I tried again and this time the engine wouldn't tick over at all, just the dash lights flickering on and off as I am twisting the key in the ignition. I waited a while and tried again but it was the same, engine not turning over but dash lights flickering as I am twisting ignition. At this time all the electrics on the car were working fine without loss of power. Short while later Greenflag chap arrived, plugged in jump-starter and bang the engine started. He checked the battery for correct volts and it seemed all good. He mentioned the starter motor is probably dead and I guess from searching the forum this is a common problem. I know this topic has been done to death but I didn't want to hijack another thread with all my questions below.
    My question, does this actually sound like the starter motor?, if so then how hard is it to change, does anyone have a guide or/with pics? Any specific tools also torque settings for bolts as I heard over tightening could snap bolts in gearbox? If I am changing the SM I'll buy new but any particular part numbers or type to get (euro parts are very close to me and guess ill buy from there if there is any recommendations)? Since the car is 5 years old ill also buy a new battery and thought about the Varta silver 74ah, is this ok?
    Sorry for the long post and many questions. Thanks in advance for all replies.
    Apr 2011
    63
    In my opinion your problem is your battery(if you havent changed in last 5 years).In every ocassion first check your battery and after that your starter motor.
    Jan 2012
    SW London
    794
    When u try to start the car can u hear the starter motor trying to turn?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Sep 2012
    16
    Quote Originally Posted by Sidhu88 View Post
    No don't think i can I guess if I could then then the engine would try and turn too but that doesn't happen, I turn the key and all the dash lights flicker on off but dimmed.
    Fossie
    Rhubarb Triangle
    3,969
    Check first that the battery earth is making a proper contact, both at the battery end and at the chassis end. Sometimes a bad earth can cause your symptoms.
    Sep 2012
    16
    Checked both connections, seem solid and clean.
    Bought a new battery today, Varta Silver 74ah, getting late so will fit tomorrow morning.
    Also tried to start the car again and it seems the starter motor is turning over or trying to (can hear hear the clicking/ticking) but still no go.
    Fossie
    Rhubarb Triangle
    3,969
    If, after fitting the new battery, you still get the clicking of the starter solenoid but it doesn't turn over then it's definitely the motor. The clicking is the solenoid pulling in but if the motor doesn't turn then it's goosed !
    Unless of course, the earth that you have checked looks ok but isn't !
    cubby likes this.
    Sep 2012
    16
    ok will update once I've fitted the new battery, fingers crossed. The earth connections look ok, to double check this is the short thick cable running from negative connector on battery to body earthed just near top of shock tower/firewall.
    I sound like a right nOOb
    Fossie
    Rhubarb Triangle
    3,969
    Forgot to mention you need to check the earth connection from starter motor to chassis. That has also been known to be a problem.
    Sep 2012
    16
    Quote Originally Posted by jimpa10 View Post
    Swapped the batteries over and bang the engine started on first turn of key. Went for a drive to warm up starter motor to see if heat had anything to do with the problem and its all good.
    Is it safe to say at this stage the battery was the problem?
    Jun 2011
    249
    ive got a similar problem, i left my ignition on for about 30mins wouldnt start was just hearing it ticking jump started and its fine, also got a battery test at halfords and guy said battery is good
    A3 S Line 2.0 TDI Sportback - DSG
    BOSE, cruise control, bi-xenons, MFSW, Heated seats, paddle shifts, ipod connection
    19" Speedlines | Reverse camera | Eibach Sportline Springs | MY09 LED Tails | Eibach Spacers Front 10MM Rear 12MM | Pioneer HU | Private Plate | Tints | LED numberplate | Interior Light Kit
    Sep 2012
    16
    Quote Originally Posted by andrecc View Post
    Greenflag chap checked my battery too when I first broke down and said battery is good. considering I've changed it, then it must be the battery not giving the starter motor enough juice to crank over.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Re: Help: A3 starting problem
    Looks like the battery.
    VCDS USER
  1. Help!!! Car starting problem!!!
    By ant123456 in forum Volkswagen and other VAG
    Last Post: 17th April 2009, 23:00
  2. S3 Starting Problems ???? I Need Help !!!!
    By jamieface in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2007, 12:59
  3. 1998 S4 warm starting problem? HELP!
    By myfirsts4 in forum General Technical / How To
    Last Post: 15th July 2007, 11:19
  4. Starting problems on 98 A4 1.8t need help
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th August 2004, 00:25
  5. HELP (STARTING PROBLEMS)!!!!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 20:13
