Results 1 to 10 of 10
    Sep 2012
    Lichfield
    389
    Dewiper - boot liner help?
    I'm sure I'm being a muppet, but again, searched and found nothing..
    I want to Dewiper my motor, I have a 25mm bung sat in my passenger side. I had a crack at it yesterday, removed the two obvious torques and gave the boot liner a yank, but nothing?
    Is it held on with clips or is there something else securing it?
    I don't want to go breaking anything, so any help would be appreciated! Thanks
    dex140's Avatar
    Dec 2009
    190
    I cant recall where the torx are exactly but the trim itself is held on by some very strong clips!
    Sep 2012
    Lichfield
    389
    So it's simply a case of removing the 2 torx and giving it a good yank?
    Dsport's Avatar
    Sep 2010
    West Yorks
    140
    Remove the 2 x torx put a flat screw driver under the bottom of the panel at the left hand side and pop them out one by one
    there is 4 clips on the bottom and 4 on the top it will get easier as you go along
    2.0 A3 work in progress
    Sep 2012
    Lichfield
    389
    I managed to undo 4 clips in total and got no further, I physically cannot see how it is possible..
    radhaz's Avatar
    Sep 2012
    Monterey, CA
    Once the side clips are off, reach in and pop the interior clips. At least that's what ELSA says.
    Dsport's Avatar
    Sep 2010
    West Yorks
    140
    Quote Originally Posted by BradHatton View Post
    Have you had your wheatabix they will come just pull harder
    27,126
    Dont use a screwdriver as it will damage the paintwork & any condensation or possible leaks will start to rust, use a piece of wood or get the trim plastic tools to make some room in there, but yes give it a good tug downwards, best to get someone to hold the bootlid upwards, whilst you use both hands to grab the trim & pull downwards.
    Use some angled pliers to remove the clips stuck in bootlid, make sure you re-tension the spring slips so they stay tight in the plastic trim when refitting, test all bootlid electrics whilst its of before refitting trim & most of all, have patients & take your time to line up all correctly.
    You may also need a wiper puller as they get stuck with scale & grime.
    Jun 2011
    59
    And most of all listen to this man as he's a ninja
    As Nigel said the wiper might not budge even after threatening with bad language, hitting with a hammer, using WD40 and spraying it with Coke :D
    27,126
    Quote Originally Posted by J_V_DUB View Post
    LMAO thats true mate, we tried all known things that day including monsoon rain, didnt move.
  1. Gepard Boot Liners
    By Caesium in forum General Chat
    Last Post: 28th August 2008, 21:01
  2. A3 electric mirror switch and boot liner
    By Shug1874 in forum Parts Requests
    Last Post: 29th July 2008, 15:27
  3. Boot liner for A3 3Dr Quattro?
    By funguf in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2007, 22:15
  4. s3 boot liner
    By imported_fingermouse in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2006, 11:08
  5. S3 Boot problem...help needed...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 23:39
