AH FabricationsSky Insurance
    Apr 2012
    Helsby, near Chester
    158
    Drivers side electric window not working*
    Hi
    I opened my driver side window and a loud bang happened sounded like a stone had been throw at the window the window went back up and is now not working but the left one is fine any ideas ? Cheers
    If Carlsburg made cars.... It would be an Audi !
    Jan 2012
    SW London
    794
    Smash it. YOLO
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Jan 2012
    SW London
    794
    Just kidding. Sounds like it may have slipped out of one the runners and the glass dropped down to the bottom of the door. There are normally two so the other one could have pulled it back up but if there are any sensors it may stop u from opening it again. Maybe. Could be very wrong. Try disconnecting ur battery until the ECU resets and try again. Takes about half an hour
    VCDS User
    27,121
    Remove door card & the trim with access to the inside of door chassis & see if anythings broken, but sounds like the module or the runners.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    sounds like maybe a rivet sheared or something was your window frozen shut at the time? at any rate you wont know untill the door card is off
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Apr 2012
    158
    Thanks for the advice ph1l that sounds painful will get it into a garage at the weekend
  1. Drivers side elec window not working
    By Red_Stafford in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th July 2011, 09:33
  2. Driver's side electric mirror not working
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2010, 06:50
  3. No lights on buzzer, drivers side puddle light not working..
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th February 2010, 13:54
  4. Electric Windows not working?
    By audi58 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2010, 21:43
  5. Drivers side electric window fault
    By Strider81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2007, 00:06
