Badger5EM Tuning
Results 1 to 19 of 19
    Jun 2011
    Planet Earth
    16
    Dash warning lamp like car skidding?
    I have a dash warning lamp just to right of top like a car skidding and my book is at home.
    Can anyone help?
    2006 A3 2.0TDI S-Line Quattro Sportback in Mauritius blue -Sold
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Traction control light ESP, have you pushed the button by accident on the console and turned it off?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jun 2011
    Planet Earth
    16
    Red face
    I did give the inside a good clean at the weekend - I'll check this out, Cheers.
    Jun 2011
    Planet Earth
    16
    I tried pushing the ESP button a number of times and the light stays ON. I also switched the car on and off many times but nothing turns it off!
    I even tried holding it down for 10 seconds push just in case.....
    I guess I got an expensive issue somewhere. Could this be linked to the noisy 2,500 rpm haldex vibration issue I have?
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    get it VCDS scanned and I should think it will be the ABS sensor.
    The haldex problem certainly doesn't sound too clever..
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Doesnt sound that great mate any Haldex noises from the rear coupled with lights are a bad sign... :-/
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    this thread will get your wallet twitching... ESP Fault please see owners manual
    Jun 2011
    Planet Earth
    16
    Not good reading...
    I dont get anything on the DIS just the warning light.
    I think the rear pads are very low - could that be the cause?
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    traction/ESP light can be due to hundreds of things, some cheap fixes some not. I had it on mine for a while and turned out to be an ABS sensor which was replaced under warranty thank feck. Best thing to do is have the car scanned as the lads suggested
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
    27,099
    Brake sensor wear sensor shows up in the dis.
    Get it scanned, cause atm we're pissing in the wind, as correctly stated could be untold reasons for the light, including a momentary press of the esp button.
    Jun 2011
    Planet Earth
    16
    VCDS Scan
    Okay got a scan done by simfin
    ABS Sensor and AWD Haldex.
    Could an ABS sensor issue cause the 2,500 rpm vibrations in the AWD Haldex?
    Monday,01,October,2012,18:30:37:44370
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 7D
    VIN: WAUZZZ8P06A108900 Mileage: 83370km/51803miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 BA HW: 028 101 184 7
    Component: R4 2,0L EDC 0000SG 7000
    Revision: 12345678 Serial number: AUX7Z0ENFNE04Q
    Coding: 0000172
    Shop #: WSC 06314 000 00000
    VCID: 63C033E2A2F8EA005C7
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0023170
    VCID: 72EE46A66D027388271
    1 Fault Found:
    01435 - Brake Pressure Sensor 1 (G201)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
    Component: KlimavollautomatH17 0260
    Revision: 038799 Serial number: 8P0820043P
    VCID: 397CB18A70F4C0D026B
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Revision: 00H36000 Serial number: 00000002304777
    Coding: 01884F01B214100000160000160000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408ADC6E132E9118615
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H12 3760
    Revision: 91H12376 Serial number: 003620058J88
    Coding: 0071612
    VCID: 428ED6661D228308771
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000012
    VCID: 78FA748E0B7E19D8195
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 224NED06007457
    Coding: 0005413
    Shop #: WSC 00581 210 64475
    VCID: 3778B7B246E0D6A0D0F
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 3000105B038134
    Coding: BD3F0B4007002103
    VCID: 2B509BC28AA86240A47
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 C
    Component: HALDEX 4Motion 0108
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 2D5495DAB4BC6C70BA3
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0ENFNE04Q
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 346280BE57963DB8F5D
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D088505489FC63300
    Shop #: WSC 00505 210 91473
    VCID: 3C72A89E7FC6F5F83DD
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000688
    VCID: 418CD96A182498106EB
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 195 HW: 8P0 035 195
    Component: symphony II EU H58 0460
    Revision: 23S Serial number: AZIZ4E6155655
    Coding: 0021201
    Shop #: WSC 130873 007 00000
    VCID: EFE8CFD2FE30DE6048F
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    27,099
    Quote Originally Posted by BlueTDI View Post
    Coding: 0000172
    Revision: 00H13001
    Coding: 0023170
    1 Fault Found:
    Coding: 0000001
    1 Fault Found:
    Oh dear G201 error is not a good thing.
    Did he clear & then retest after a short test drive?
    Jun 2011
    Planet Earth
    16
    He did a clear and retest yes, this is the second logfile. The dash light is still on.
    No short test drive though - is that a problem?
    The other entry in the first log was
    Coding: 0000172
    1 Fault Found:
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 882 /min
    Torque: 42.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.36 V
    Bin. Bits: 11000100
    Temperature: 9.9°C
    Bin. Bits: 10110000
    Readiness: 0 0 0 0 0
    27,099
    G201 is a problem yes, do some searching online mate.
    Jun 2011
    Planet Earth
    16
    27,099
    Just be careful not to let the abs module run dry, as it can be a pig to bleed all the air out of them.
    Jun 2011
    Planet Earth
    16
    A few years ago I might have tried this but I think its over to the specialists for a quote.
    The car drives fine just no abs I guess, which I can live with. If this sensor is nothing to do with the driving vibration Id rather get that fixed first tbh.
    I used to have Celica that was awful with the abs kicking in all the time so some motorsport place swithced if off and it was great afterwards.
    Jun 2011
    Planet Earth
    16
    To finish this thread I took the car to Unit 18 Automotive in Old Wolverton, Milton Keynes and they diagnosed the ABS Pump Sensor and suggested some thicker 90 oil in the diff as there was a little noise from it when the wheels were turned manually.
    Light now extinguished but diff noise still there. I will take it back sometime for further investigations on the noise.
    27,099
    Thanks for reporting back.
  1. Warning lamp staying on.. Need Help!
    By i_storm2k in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 23:09
  2. SRS air bag warning lamp
    By xenodrew in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th May 2006, 14:13
  3. Coil sign stays on dash after starting the car.
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2005, 17:31
  4. Warning lamp on DIS
    By JasonM in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2004, 21:40
  5. ESP Warning Lamp
    By sharpr in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 22:04
