Dash warning lamp like car skidding?
BlueTDI
Planet Earth
I have a dash warning lamp just to right of top like a car skidding and my book is at home.
Can anyone help?
Traction control light ESP, have you pushed the button by accident on the console and turned it off?
I did give the inside a good clean at the weekend - I'll check this out, Cheers.
I tried pushing the ESP button a number of times and the light stays ON. I also switched the car on and off many times but nothing turns it off!
I even tried holding it down for 10 seconds push just in case.....
I guess I got an expensive issue somewhere. Could this be linked to the noisy 2,500 rpm haldex vibration issue I have?
get it VCDS scanned and I should think it will be the ABS sensor.
The haldex problem certainly doesn't sound too clever..
Doesnt sound that great mate any Haldex noises from the rear coupled with lights are a bad sign... :-/
Not good reading...
I dont get anything on the DIS just the warning light.
I think the rear pads are very low - could that be the cause?
traction/ESP light can be due to hundreds of things, some cheap fixes some not. I had it on mine for a while and turned out to be an ABS sensor which was replaced under warranty thank feck. Best thing to do is have the car scanned as the lads suggested
Brake sensor wear sensor shows up in the dis.
Get it scanned, cause atm we're ******* in the wind, as correctly stated could be untold reasons for the light, including a momentary press of the esp button.
Okay got a scan done by simfin :thumbsup:
ABS Sensor and AWD Haldex.
Could an ABS sensor issue cause the 2,500 rpm vibrations in the AWD Haldex?
Monday,01,October,2012,18:30:37:44370
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 7D
VIN: WAUZZZ8P06A108900 Mileage: 83370km/51803miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 BA HW: 028 101 184 7
Component: R4 2,0L EDC 0000SG 7000
Revision: 12345678 Serial number: AUX7Z0ENFNE04Q
Coding: 0000172
Shop #: WSC 06314 000 00000
VCID: 63C033E2A2F8EA005C7
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0023170
VCID: 72EE46A66D027388271
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
Component: KlimavollautomatH17 0260
Revision: 038799 Serial number: 8P0820043P
VCID: 397CB18A70F4C0D026B
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002304777
Coding: 01884F01B214100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408ADC6E132E9118615
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 003620058J88
Coding: 0071612
VCID: 428ED6661D228308771
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000012
VCID: 78FA748E0B7E19D8195
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0420
Revision: D06 Serial number: 224NED06007457
Coding: 0005413
Shop #: WSC 00581 210 64475
VCID: 3778B7B246E0D6A0D0F
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 3000105B038134
Coding: BD3F0B4007002103
VCID: 2B509BC28AA86240A47
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 C
Component: HALDEX 4Motion 0108
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 2D5495DAB4BC6C70BA3
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0ENFNE04Q
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 346280BE57963DB8F5D
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D088505489FC63300
Shop #: WSC 00505 210 91473
VCID: 3C72A89E7FC6F5F83DD
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000688
VCID: 418CD96A182498106EB
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H58 0460
Revision: 23S Serial number: AZIZ4E6155655
Coding: 0021201
Shop #: WSC 130873 007 00000
VCID: EFE8CFD2FE30DE6048F
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
Coding: 0000172
Revision: 00H13001
Coding: 0023170
1 Fault Found:
Coding: 0000001
1 Fault Found:
Oh dear G201 error is not a good thing.
Did he clear & then retest after a short test drive?
He did a clear and retest yes, this is the second logfile. The dash light is still on.
No short test drive though - is that a problem?
The other entry in the first log was
Coding: 0000172
1 Fault Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000100
Temperature: 9.9°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
G201 is a problem yes, do some searching online mate.
Just be careful not to let the abs module run dry, as it can be a pig to bleed all the air out of them.
A few years ago I might have tried this but I think its over to the specialists for a quote.
The car drives fine just no abs I guess, which I can live with. If this sensor is nothing to do with the driving vibration Id rather get that fixed first tbh.
I used to have Celica that was awful with the abs kicking in all the time so some motorsport place swithced if off and it was great afterwards.
To finish this thread I took the car to Unit 18 Automotive in Old Wolverton, Milton Keynes and they diagnosed the ABS Pump Sensor and suggested some thicker 90 oil in the diff as there was a little noise from it when the wheels were turned manually.
Light now extinguished but diff noise still there. I will take it back sometime for further investigations on the noise.
903
6
790
Abi
