Chris NottJMB Retrofits
Results 1 to 25 of 25
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Aftermarket brake pads?
    Hello all,
    I'm wondering if there are better brake pads out there than what VAG offers.
    I'm looking for better initial bite, and am willing to trade extra dust and noise for that.
    Any suggestions? Thanks in advance.
    -Ben.
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Re: Aftermarket brake pads?
    Do Pagid do a fast road pad for your car? Used these in the past on previous Golfs and always had god results from the. Theyalso aren't as harsh as the EBC pads and are gentle on your disks.
    J.
    JaminBen's Avatar
    Jan 2005
    532
    Thanks J! I'll look around and see what I can find.
    JaminBen's Avatar
    Jan 2005
    532
    Shhhesh, just spent close to an hour looking for a 3.2 application: no luck!
    Tried EBC and EBC direct, and a bunch of other sites... This sux!
    Anyone have an idea?
    Ibis S3 Fan Club
    Jan 2005
    Somewhere Cold
    1,496
    Sorry can't help JB. But after swapping all my wheels around this afternoon I took a close look at my pads. What the h*ll do Audi make them out of, cause mine look brand new after 13k.
    Either that or I brake like a pussy [img]/ubbthreads/images/graemlins/wink.gif[/img]
    JaminBen's Avatar
    Jan 2005
    532
    Well fellas, I give up: haven't found anything!
    Yup the standard pads are "long-life" too, lol!
    I'd gladly trade faster wear for more bite... The little twisty roads I drive on most of the time have lots of "nice" blind turns. Have to slow down for those... The standard pads demand that one hit the brake pedal hard and very fast to achieve significant initial deceleration...
    imported_DSGSport
    From what I can see EBC do list a set for the 3.2.
    Have a look at this.
    I might be wrong
    http://www.ebcbrakes.com/Assets/2005ebcintcat.pdf
    little_wing's Avatar
    Oct 2004
    Hampshire
    178
    I could see rear pads for a 2003 -> 3.2, but nothing for the fronts on that ebc catalogue...
    imported_S_Line
    LOL at you lot and EBC,
    Cheap skates !
    If you want proper pads i would sujest Tarox.
    Danielson's Avatar
    Jun 2004
    UK
    704
    all i will say is green stuff are crap, and they made a real mess of my old discs. allthough they were good at not producing a lot of brake dust. but not good when you wana stop quick.
    TTLAW's Avatar
    Nov 2003
    Walsall, England
    124
    I think when I called AMD they said that the 3.2 Front Pads are from the RS4 (Old One). This is certainly the case on 3.2 TT's. EBC do the red stauffs to fit.
    Steve
    JaminBen's Avatar
    Jan 2005
    532
    Hey, thanks for the input everyone.
    I have no personal expersince with EBC, nor do Iknow anyone with dirdet experience with them. Are they bad?
    I'll look at Tarox, see what I can find for the B5 RS4, and Rich@JBR is looking as well.
    S-Line, I know you didn't fault the brakes at the track, but I think we could get more initial bite from pads on our 345mm / 282mm discs.
    JaminBen's Avatar
    Jan 2005
    532
    well, here's TAR-OX's (acrobat) catalogue page for Audis:
    http://www.tarox.com/audi.pdf
    and sadly, no A3 3.2 app.
    The only S4 listed has 240mm discs (or something similar)...
    The search goes on...
    Dec 2004
    Sunny South Coast
    4,368
    Personally I would avoid tarox stuff unless your going for one of thier monster brake conversions and if that is the case then you may as well save a load of cash and get the mov-it set instead.
    Had Tarox discs and pads on my mkII Golf 2.0Gti and hated them, expensive and useless and that was on a light car.
    J.
    imported_trident21
    I think not! The RS4(old) and the 3.2 TT has e 2 piston capiler and the A3 3,2 has a one piston capiler. But just looking at photos I think that the S4 B6 (probebly the B7 too) has the same capiler and discs as the 3.2 A3. Not sure but some one might know!
    So look at the ECS under the S4 section and make your own appinion.
    Dec 2004
    Sunny South Coast
    4,368
    Does the 3.2 not have the same brake setup as the R32 then?
    J.
    imported_trident21
    Yepp... Thats what the Etka says at least.
    Dec 2004
    Sunny South Coast
    4,368
    If the 3.2 has the same brakes as the R32 then it's a 2 piston caliper on the front.
    J.
    Oct 2004
    Hampshire
    178
    what size were the r32 fronts, and didn't they use those 'floating' discs?
    Dec 2004
    Sunny South Coast
    4,368
    The r32 fronts are 334mm x 32mm and no there not the floating type just the standard 1 piece disc. Actually from the the w8...
    J.
    JaminBen's Avatar
    Jan 2005
    532
    345mm, one piece, on the A3.
    imported_S_Line
    HEy i have a idea - what about the standard Audi Ones ?
    JaminBen's Avatar
    Jan 2005
    532
    What are "Ones"? Are they like disposable wet wipes? j/k ;-)
    Honestly, you just may have a point there. Although I can't help thinking the standard Audi ones have no initial "bite".
    Perhaps it isn't the pads' fault, and that I should be looking to reduce caliper flex instead (i.e. go for an entirely different setup). Or maybe go for stainless brake lines? (Although those never did much for me in the past, on 3 different automobiles.)
    Perhaps I should simply take a chill pill and leave well enough alone? Nah, forget that: this car is good, but it could easily be great!
    imported_S_Line
    the brakes on my a3 are better than the brakes on my WR1, leave alone mate [img]/ubbthreads/images/graemlins/wink.gif[/img]
    JaminBen's Avatar
    Jan 2005
    532
    But they are so very inferior (in terms of initial bite only) to my SL's. And it's only a 500, not an AMG. And it's about 600 pounds heavier than the A3... Yet, when you hit the stop pedal, it bites hard.
    There is definitely room for improvement.
