Volks AutosJMB Retrofits
Results 1 to 10 of 10
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Over boost now under boost?
    Hi, dads turbo went on his TDI 170 Audi A3 which had a fault that was under boost now the turbo has been replaced he's now getting over boost? Can put your foot down and it won't even get to 2k rpm sometimes it will, Isn't drivable as hasn't got any power whatsoever and when you do rev it, it chucks out lots of black smoke
    any ideas guys?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    First question are: how have you measured the boost, where the replacement turbo came from and who fitted it?
    If done by a garage, they should have calibrated the boost pressures.
    Perhaps the actuator arm needs adjusting/ stuck open
    Fossie
    Rhubarb Triangle
    3,969
    Take it straight back to them and tell them the problem. You must have some sort of warranty with them.
    kanecullen89's Avatar
    Jul 2009
    358
    Without knowing all the details it sounds to me like they've possibly fitted another dud turbo. Take it back and get them to sort it
    Apr 2012
    UK, Portsmouth
    601
    how do you calabarate the boost pressures? Its a recon turbo that my dad has fitted ive checked everything and hes fitted it correctly, not sure he has calaberated the boost pressure.
    Hes been having problems with it for a while now even after being to a garage and its costing him too much to send it back to another garage but looks like its the only choice.
    Also, measured the boost via a Blue Point live data.
    Apr 2012
    UK, Portsmouth
    601
    Also, what model did Audi do an injector recall? As my dad was told today his is a different model and isn't under the recall.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Actuator rod.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Quote Originally Posted by MrLapou View Post
    Actuator rod.
    ^^^ Almost guaranteed. Did you measure the actuator rod position against the old turbo?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Apr 2012
    UK, Portsmouth
    601
    Dad said that was done when the turbo was reconditioned. Anyone know the distance for a 170?
    27,099
    As its a 170, is it a vacuum or electrically controlled actuator as such.
  1. S3 Spluttering and holding back under boost.
    By Barks in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2011, 18:08
  2. S3 Under Boosting, Changed MAF, no improvement :(
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2010, 23:56
  3. Bad misfire under boost
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2009, 22:45
  4. Huge missfire under boost
    By S3-Andy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 15:43
  5. ko4 upgrade now no boost???
    By s3 ginga in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2008, 21:56
