Sky InsuranceAH Fabrications
Results 1 to 12 of 12
Thread: Injector recall
    9
    Injector recall
    Will audi change the injectors FOC if the DPF has been removed?
    Jun 2011
    Roslin
    105
    Can't see them bothering to check so I would say yes to your question..
    Jan 2009
    33
    Careful here, not sure if there is a software update as well, so if youre remapped this could cause a problem or two.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Yep, they will do a software update, meaning you will lose your map, and also have your DPF warning lights etc come on as I assume you would have had this mapped out on your removal.
    So yes, they probably will, but be prepared to take your car back to who mapped it.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Jun 2011
    Roslin
    105
    After I had my injectors done I hd te remap checked and the software was untouched ie remap was not altered.
    Mar 2007
    Cambs
    471
    allen, have a read of all the posts relating to issues after injectors, if the car is running fine and it was me, id leave well alone!
    Jun 2011
    249
    I've got them replaced and car is running fine. Apart from a flat battery the other day or so.
    A3 S Line 2.0 TDI Sportback - DSG
    BOSE, cruise control, bi-xenons, MFSW, Heated seats, paddle shifts, ipod connection
    19" Speedlines | Reverse camera | Eibach Sportline Springs | MY09 LED Tails | Eibach Spacers Front 10MM Rear 12MM | Pioneer HU | Private Plate | Tints | LED numberplate | Interior Light Kit
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    There is a software update thats meant to be applied when they change the injectors, however most dealers are totally unaware of it. If you're car is running ok personally I wouldn't do the recall (from my experiences anyway), the recall wont expire so if you need it in the future you can still get the work done.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    a3sline_nottingham's Avatar
    Mar 2012
    64
    I have an a3 2.0tfsi 56 plate. Hd a recall on the coil pack but still having juddering when cool and pulling through gears, oil was on the second plug when changing them and I'm pushing for audi to do the injector but my car has no outstanding recalls!!
    pvery frustrating and it's now with audi tomorrow for a 1hour flat charge for diagnostics.
    if there is a know problem with injectors in the later model, I think 07 onwards, can I push to get it foc
    Jun 2011
    249
    after my last post on this thread of getting the injectors done, my car is running fine.
    work was done at victoria audi.
    chris1988brown's Avatar
    middlesbrough
    578
    [QUOTE=Dannykn9;1682394]Yep, they will do a software update, meaning you will lose your map, and also have your DPF warning lights etc come on as I assume you would have had this mapped out on your removal.
    So yes, they probably will, but be prepared to take your car back to who mapped it.[/QUOTE
    this isnt true, i had the iinjector recall done and ive got custom map and miltek dpf delete and didnt effect them doing it FOC and my car is still mapped
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    stetheo's Avatar
    Oct 2012
    328
    I had my dpf removed and car remapped on Monday of this week, it then went in to Audi on Tuesday for the Injector recall.
    Checked the map after the injector recall had been done and it had not been touched so it is still mapped.
    Current:
    8P2 S3 Phantom Black | Sunroof, RNS-E, AMI, FBMFSW, Bluetooth, Auto lights & wipers, CHL, LED Interior light pack, Black Styling pack, Miltek Catback, MY11 rear lights and remapped by Unicorn Motor Developments
    Previous:
    8P2 A3 2.0 TDI 170 S Line Quattro Grey | Remapped
    8L A3 1.9 Tdi 100 Sport Black | Remapped to 130
  1. Replies: 23
    Last Post: 21st July 2012, 20:58
  2. Injector Recall for PD170 - Might be already known to you lot.
    By drnutta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2012, 01:44
  3. injector recall
    By craiga in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th April 2012, 21:33
  4. 170 TDi Injector recall
    By Gogsie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th February 2012, 23:03
  5. 170PD Injector Recall
    By grantDUBshaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 16:50
