Blacky165
2005 8P A3 2.0L TDI
I've been trying without luck to solve my remote key locking issue. I've had several door lock components replaced which has completed solved the manual opening/closing procedure (new lock cylinder & door lock module).
However the remote locking is still a mystery. I've bought a full copy of VCDS and and attempted to follow the remote coding procedure. The car appears to learn both remotes by flashing the indicators when the lock button is pressed during the key adapation in central convenience (good sign!), but once you exit VCDS the remotes seem to forget everything. Please note the immobiliser works perfectly on both keys, and the batteries are new and have been tested.
I'm still new to VCDS and haven't ventured beyond the autoscan and key adapatations yet - can anyone help?
Below is my autoscan report, perhaps this will help. Surprsied to see so many radio faults, but presume this is because I've installed a bluetooth parrot. I've also tried clearing the fault codes and retrying the VCDS key learning procedure - no luck.
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P16A028022 Mileage: 154870km/96231miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 7000
Revision: 12345678 Serial number: AUX7Z0E5FNS0BG
Coding: 0000078
Shop #: WSC 06314 000 00000
VCID: 78F599440BC854E
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 S HW: 02E 927 770 AE
Component: GSG DSG 082 1102
Revision: 04808020 Serial number: 00000804120194
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 234F9E28E2CEE76
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 408531A41398DCE
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH16 0200
Revision: 208348 Serial number: 8P0820043H
VCID: 31636460A832456
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002044373
Coding: 01884F06A214100000000000000000000008FE175C0100
Shop #: WSC 06314 000 08192
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H11 3520
Revision: 91H1135 Serial number: 0037W000B10B
Coding: 0071612
VCID: 47972AB836B6EB6
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
Component: Lenksäulenmodul H34 0070
Coding: 0011112
Part No: XXXXXXXXXXX
Component: Lenkradmodul H03 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0410
Revision: D03 Serial number: 2245ED03001571
Coding: 0000413
Shop #: WSC 00164 210 82222
VCID: 37775A7846569B6
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001056198B05
Coding: 3F0F0B42070101
VCID: 2A51730C85E436E
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 22
Reset counter: 221
Mileage: 153485 km
Time Indication: 0
Date: 2012.08.14
Time: 19:11:03
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0E5FNS0BG
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0000560
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 336F6E68522E776
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H03 0040
Coding: 198000186D288505489AC63300
Shop #: WSC 00046 046 52295
VCID: F9F31C40B0C2CD6
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
1 Fault Found:
01179 - Incorrect Key Programming
000 - -
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001264844
VCID: F0E52164E3B88CE
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000560
VCID: 418334A01892D56
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3E2585089
Coding: 0001001
Shop #: WSC 06435 000 00000
VCID: 32616B6CAD347EE
5 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 213
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 213
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 213
00852 - Loudspeaker(s); Front
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 207
Mileage: 154439 km
Time Indication: 0
Date: 2012.09.06
Time: 20:02:05
00858 - Connection; Radio ZF Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 184
Mileage: 134196 km
Time Indication: 0
Date: 2010.12.04
Time: 14:52:49
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B7810B40A216
Chassis Type: 1K0
Coding: 0000078
4 Faults Found:
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 1008 /min
Torque: 68.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
Coding: 0000020
Revision: 00T12001
Coding: 0021122
Coding: 00062736
Shop #: WSC 06314
Coding: 0071612
Coding: 0011112
Coding: 0000413
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 221
Mileage: 153485 km
Time Indication: 0
Date: 2012.08.14
Time: 19:11:03
Coding: 0000560
1 Fault Found:
000 - -
Coding: 0000560
Coding: 0001001
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 213
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 213
Freeze Frame:
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 213
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 207
Mileage: 154439 km
Time Indication: 0
Date: 2012.09.06
Time: 20:02:05
Freeze Frame:
Fault Priority: 5
Reset counter: 184
Mileage: 134196 km
Time Indication: 0
Date: 2010.12.04
Time: 14:52:49
