EM TuningAH Fabrications
Thread: Idle Problem
    Oct 2011
    Idle Problem
    Hi Guys,
    I have a bit of an issue which I'm hoping someone can give me a rough idea of what the problem might be.
    I had my car serviced a couple of weeks ago (stock 2008 S3) and everything has been great, but this morning when I was at the traffic lights it decided to start accelerating for no apparant reason. At first I thought I had caught the pedal but it happened more than once, I managed to film it in action.
    Take a look here, I'm sat with the engine running, in neutral, handbrake on... :
    S3 idle - YouTube
    You can see it happen at the start and also at the 25 second mark.
    It's as if I'm slowly accelerating but it definitely isnt my foot doing it! Maybe she's become self aware!?
    Any help would be much appreciated
    Thanks in advance!
    Aug 2011
    vacuum leak, mine did exactly the same thing when the PCV failed
    Oct 2011
    Thanks Dezz,
    So what's the fix and how much will I be looking at? (Sorry, I'm no mechanic!)
    Aug 2011
    I'm not sure of the cost as mine was replaced under warranty but I don't think the PCV is expensive.
    Personally I would take to a mechanic as if it is a leak they should be able to find it pretty quickly.
    Oct 2011
    I have been advised on this:
    Revo Technik Performance Online Shop. Revo PCV Revamp For 2.0 TFSI
    What are your thoughts on this upgrade?
    Also is it worth upgrading the air filter to the below while I'm at it?
    Revo Technik Performance Online Shop. Revo Replacement Air Filter Element For VAG 2.0T FSI
    Thanks again
  1. AUDI A3 idle problem 1.6 please help
    By m3will in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2008, 12:06
  2. Slight idle problem in the morning
    By nik patel in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2008, 13:53
  3. A3 1.8T '01 - WTF! Bad Idle Problem?
    By IndieA31.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2007, 10:41
  4. audi 80 cabriolet 2.0L 1994 idle problem
    By tibbenham in forum Classic Audi Forum
    Last Post: 25th April 2007, 18:18
  5. a3 1.8t dbw idle problem
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2007, 23:09
