JMB RetrofitsChris Nott
Results 1 to 19 of 19
    Mar 2007
    Cambs
    471
    TDi owners - ever seen a warning message flash up whilst starting?
    Hi guys,
    As title, I have seen, or rather not seen a very quick warning message and I think beep flash up on dash when starting.
    It seems after this the car has not run so good, maybe, trying to eliminate things.
    If you have had this and know what it says, please tell me
    Thanks!
    scotty0189's Avatar
    Prepairing to Land
    Aug 2010
    Aberdeenshire
    72
    After an Audi tech disconnected my battery I had an ESP warning that did that.
    Other than that, just the usual Passenger Airbag warning.
    Mar 2007
    Cambs
    471
    Ok cheers
    i_786_i's Avatar
    Aug 2012
    57
    Quote Originally Posted by scotty0189 View Post
    This is normal for the ESP to come on after battery-disconnect, it is also noted in the handbook that this will happen.
    This will go back after driving a for meters and turning the steering wheel.
    i_786_i's Avatar
    Aug 2012
    57
    Quote Originally Posted by Cossie_boy View Post
    Hi guys,
    Thanks!
    You may need to link up to VAGCOM to diagnose if the error is picked up in the ECU, which it normally will be
    27,126
    Hi guys,
    Thanks!
    Video the dash when starting car & hopefully it will be captured in a frame so can be seen.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    The new ECU update applied after the injector recall, seems to do this (accompanied by a long beep) although it doesn't seem to mean or indicate anything.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    c_w
    1,061
    I get an "ESP Fault, please see driver's handbook" with warning beep on practically every ignition switch on. But there is no fault as it goes off straight away.
    Jun 2011
    Roslin
    105
    Quote Originally Posted by c_w View Post
    Agree with above. 2007 170 SB with recall completed.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Guys, we have had a few threads on this in the past.
    Generally when you get a quick warning in start up with ESP etc and it clears straight away, it tends to mean your battery is on its way and something to do with the voltage.
    Everyone including myself who had this problem upgraded their battery to a new one and viola, no more faults on start up.
    Have not had the problem for nearly a year now.
    A great battery to upgrade to, especially for the TDi is a Varta Silver E44. Excellent battery, highly recommended
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Mar 2007
    Cambs
    471
    Cheers guys,
    This morning I just caught a glimpse of ESP n FAULT!
    So guess it must be that, I was sure when its done this the car didn't run so good :/
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Cheers guys,
    Change your battery mate and all is forgotten :-)
    Jun 2011
    Roslin
    105
    Quote Originally Posted by Dannykn9 View Post
    Cheers Danny....ASN is the unofficial 4th emeregency service.....LOL!
    Now, who is gonna find the cheapest one on the net first? Amazon are £79.50 delivered....
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    That is a good price, think I paid £85 at the time.
    Mar 2007
    Cambs
    471
    Lets hope thats all it is then, although it doesnt sound lazy at all :/
    Jun 2011
    Roslin
    105
    That's my battery ordered. Plan to fit it myself.....was wondering if any of you guys have done it and is there anything I need to look out for?
    Thanks In Advance!
    Mar 2007
    Cambs
    471
    Got it!
    After it not doing it apart from each time I videoed it, today I got it
    ESP Fault!
    Please see driver's handbook
    It also drove fine after this, so probably just imagined it was having an affect.
    27,126
    As per already stated but if you wnat to order from audi or tps, its the Varta Ultra Silver Dynamic 577400078zgb iirc, this one:
    E44 Varta Silver Car Battery 77Ah (577400078) - Car Batteries - Varta Car Batteries
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Got it!
    ESP Fault!
    Change the battery mate, it will soon cure your problem, I had the exact same thing about a year ago.
    Nigel has kindly given a link to the recommended battery. That is the site I ordered mine from. Excellent battery!
  1. Audi A3 2.0 TDI - Glow plug warning light flashing....
    By Julian1968 in forum The Welcome Section
    Last Post: 20th May 2012, 20:00
  2. a4 2.5 tdi red breake warning light flashes on start up!
    By vorsprung dork in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2011, 23:05
  3. Ever seen this before?
    By necroeire in forum General Chat
    Last Post: 11th May 2005, 16:44
  4. audi TDI allroad - service - word of warning
    By containersltd in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th January 2005, 09:58
  5. Call All A2 TDi Owners!
    By stuart_d in forum A2 forum
    Last Post: 17th October 2003, 08:20
