EM TuningAH Fabrications
Results 1 to 10 of 10
    Sep 2012
    warrington
    Question rev counter bouncing between 0 and 500 revs no higher
    hi i have just bought a 53 plate 2.0tdi 8p a3 and at idle the rev counter doesn't move then as you get above 15ish mph it starts to bounce to around 500rpm then back to 0 never any higher, i have tried using the search box but am struggling to find any info, is it a common problem or dose anybody have any ideas as to what it may be sensors ect or where to start looking thank you in advance for any help regards neil
    Feb 2009
    Aberdeen
    2,602
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Is the engine not revving, or is it just the dial?
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Sep 2012
    warrington
    its running and driving fine mate its just the rev dial that is not working correctly regards
    Feb 2009
    Aberdeen
    2,602
    Maybe the needle is just loose, or a wee tooth has broken off a cog somewhere? I guess it'd be a dial-out job to fix... might need a new cluster?
    Hunt is over
    Sep 2012
    warrington
    would i be better off getting it repaired as im assuming a new cluster would need recodein to the ecu to keep the mileage ect regards neil
    Feb 2009
    Aberdeen
    2,602
    To be honest, I don't know. Even if I knew why it wasn't working properly, I still wouldn't be the one to advise you on whether to repair or replace it. I'm sure someone with more knowledge will be along soon enough to help.
    Hunt is over
    Sep 2012
    warrington
    cheers for the help mate ill see what i get recommended and try a few things tomorrow i was checking the wireing today but am unsure as to how the rpm is read on these and couldn't seem to find many sensors on the gearbox ect if anybody knows which sensors i should be looking for it could be of great help as it has had an engine swap recently so assuming it may just be a sensor unplugged or not connected properly regards neil
    Jay.Ing's Avatar
    Jun 2008
    Southport
    259
    Get VCDS on it check for any communication issues and fault codes!
    2012 A3 Ibis White SportBack Black Edition 140
    Mods so far: H&R 50mm, Rain Light Sensor, RNS-E, Cruise control, Interior OEM LED mood light, OEM LED number plate lights, OEM LED Puddle lights, OEM LED Footwell Lights, tear drop wiping, Beep confirm on close, pressed plates, HHA & TPMS.
    Red A4 Black Edition 150Tdi.... On order!
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    Sep 2012
    warrington
    right i have had the cluster out today and if i take the plastic vented cover off the back the motor right behind the rev counter looks burnt out its a white motor covered in some black and brown dusty substance and looks like its burnt out im just wondering if anybody knows where i could get it repaired or if its a hard part to replace on my own or if i got another cluster off ebay how much it would cost to get it reprogrammed to the car thankyou for the help regards neil
    warren_S5's Avatar
    Oct 2007
    7,135
    PM 'NHN', he might be able to help you resolve this and he's back in circulation this week
  1. Replies: 0
    Last Post: 29th November 2011, 20:30
  2. Rising and falling rev counter needle on idle
    By northern monkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 10:13
  3. 2.0TDI Rev Counter, Startup and running issues......Bluefin?
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2010, 21:38
  4. Replies: 4
    Last Post: 9th June 2009, 13:42
  5. Abs warning, no aircon or rev counter
    By imported_rst99 in forum General Technical / How To
    Last Post: 2nd August 2004, 09:30
