Sky InsuranceVolks Autos
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,370
    Question Part Number needed for Fuel Pump for White Cluster?
    I'm about to replace my old red dials for the white ones. Does anybody know what part number it is ???
    NHN Quote:
    Ok well 1st thing to note is cars before the 1st facelift 8P pre 11/04 generally had the older fuel pump & also possibly missed some wiring that was added to facelift cars. Please note though my car is 07/04 & had the extra wire so contradicts audi's info in Elsawin of all places, so check for this wire on rear of current cluster 1st before thinking wiring needed, read further down for wiring info. The newer pumps from this date (according to audi's records anyway, check 1st before doing) had an extra wire added for the fuel sender/level to register properly on the clusters. So if you have the older cars then you must add a single wire from the cluster 32pin connector at pin 25 & wire this back to the underneath of the rear seats on a 3dr anyway (maybe same as 5dr, need checking) to the fuel pump & connect to pin 4 on the 5 pin connector. Now you also need to upgrade the pump on pre 11/04 cars (but check cause on my 07/04 car I had the newer wiring but old pump) to support the newer sender/level reading for fuel in the cluster. Once the pump is swapped & the extra wire fitted, then you just need to swap the cluster out & get it coded with all your keys & you're away. Now if its a new cluster or less than 100kmh then audi can set it all correctly for your existing mileage, if its more then you'd have to put up with the used cluster mileage.
    Looks like I need a part number for a pump above a 05 Reg.
    Help will be
    appreciated.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Why don't you ask Nige? Oh, I remember why.
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Digzz's Avatar
    Jan 2009
    London
    1,370
    Quote Originally Posted by N8 View Post
    lol He's not in town apparently. Plus I don't think he would give me an answer.
    *Müllërz's Avatar
    REVOlutionary
    Sep 2010
    479
    Wont it come up when you scan a 05 above car?
    Swap
    2008- A3 Sportback/5 door rear black edition bumper with parking holes
    Will swap with no holes sline bumper preferably white
    Digzz's Avatar
    Jan 2009
    London
    1,370
    Quote Originally Posted by *Müllërz View Post
    I don't have an 05 car at hand......
    It's cool thou....I think I just need to get a pump above a 05 REG .....
    Did you change your cluster ?
    Oct 2009
    Plymouth, Devon
    71
    1K0919050AB = TDI fwd
    It might be possible just to change the level sensor as thats the only reason you need to change the pump i'll be doing mine soon so i'll try and post results i'll post the other pat numbers tomorrow (left the print outs in my toolbox)
  1. Isofix part number needed for C5 A6 - please help!
    By Shink in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th September 2011, 18:22
  2. Part number needed for S-LINE Bumper! ??
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2010, 23:54
  3. part number needed for 3dr sline rear diffuser
    By DOLPHIN DIESEL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th June 2010, 13:44
  4. Relay (for fuel pump) location?????
    By sam1014 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd February 2010, 08:18
  5. Part number needed for a turbo
    By HODD in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2009, 12:03
