Monster MotorsportEM Tuning
Results 1 to 17 of 17
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Help on a few issues please - Fitted FBMFSW and now.....
    Hi guys & ladies
    After a bit of help got a few issues i need sorted.
    First issue started about 10days ago. I can put down the passenger window using the switch myside but it wont go back up when i try it and works fine on the passenger side up/down. And there no fault codes for it any suggestions? Everything was connected up and nothing seems to be visibly broken.
    Second issue possibly related to the above driverside speakers has just stopped working completely all wired up fine nothing broken or not connected. And again no fault codes, suggestions? New speaker? New loom? Pretty sure when i checked it was showing too negative wires or positive cant remember as this issue started back in June and i just forgot about it. Going to rescan the car this weekend hopefully with my friend and see if there any new fault codes.
    Third issue which is really annoying had a fbmfsw fitted two weeks ago this friday coming and since then i've had the yellow steering light on and the steering wheel is heavy as if it has no power steering at all.
    When the new wheel was fitted we had a new module, slip ring and air bag harness loom. Should i of changed the angle sensor? Rhyso scanned it for me yesterday and it bought up these:
    Fault code 02546 - steering limit stop
    00778 - steering angle sensor - no or incorrect basic setting. module, slip. He couldnt even adjust the steering at all as vagcom wouldnt let him kept bring up error everytime.
    Any help would be greatly appreciated
    Dark Vader Half sibling - MyThread
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    You obviously stuck this up before before reading your message on FB
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Apr 2010
    Nottingham
    230
    I had this problem. You need to perform the basic setting on the steering angle sensor. Can't remember off the top of my head how to do it. Just looking for my old post which might detail it......
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    Apr 2010
    Nottingham
    230
    Have a look here:
    Project FBMFSW - step 1
    Towards the bottom of the page I try and explain what I did. Hope that helps.
    TTRS FBMFSW
    MY11 Rear Lights
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Quote Originally Posted by Rhyso View Post
    Haha i did
    Quote Originally Posted by ADi Nuff Valves View Post
    Have a look here:
    Cheers fella
    Jul 2010
    881
    My Posh Golf
    *Müllërz's Avatar
    REVOlutionary
    Sep 2010
    479
    I have the same issue with my passenger window any luck with that yet ash?
    Swap
    2008- A3 Sportback/5 door rear black edition bumper with parking holes
    Will swap with no holes sline bumper preferably white
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Quote Originally Posted by *Müllërz View Post
    Nothing yet mate. Going to take the doorcard off later and have a look if i cant be bothered. If not will just do it on the weekend. It's quite annoying lol
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    If you need any new front Speakers ....I have 2 for sale ....
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Quote Originally Posted by Digzz View Post
    will keep that in mind mate
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Quote Originally Posted by Ash B View Post
    have you done the reset on the switch for the comfort function?, ie putting the window all the way down holding for 5 seconds holding up for around 10, repeat a few times, sometimes the comfort function gets screwed no faultcodes will register, if youre really strugling ive got 2 door modules for your car capable of autodim and folding lying around i can do a good price on
    also have you tried shutting via the key too? ie holding lock or unlock?
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    27,126
    Switch contacts could be worn on that path, damaged or just need cleaning, strip it down & test with meter if need be for a circuit path.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Still got the steering wheel light on, did the procedure off Ross Tech. Didnt do anything so will give it another go tonight.
    Quote Originally Posted by PH1L View Post
    Done that last night working fine now
    Thanks for the information Nigel. Do you believe that could be the issue with the speaker or window?
    27,126
    Speaker could be hardware or wiring, check the loom in the door hinge area, prone to breaks, just try other side speaker in there, also the back of the speaker is also prone to water given the rain run of channel drops above the speaker from the glass seal, but speakers usually dont go wrong, because of this stupid design fault imho.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    glad you got it fixed lad
    as for the steering am i correct in saying after the adaptation you've put full lock either way a few times? sometimes the pump doesn't engage first time
    Mods
    27,126
    Which Pump?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Yes turn the wheel and also drive the car a few metres should extinguish the light.
    As NHN hints at, there's no pump, it's an electric rack.
  1. A Few Issues Please Help !
    By a3james in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2012, 18:16
  2. help with a few issues please guys
    By daz-20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2012, 17:44
  3. Help with a few problems please?
    By jzr172 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2010, 08:18
  4. Urgent help please fitting ice link!!
    By gkf9 in forum In-Car Entertainment
    Last Post: 27th August 2007, 12:18
  5. Braking Issue Please help
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2005, 13:23
