Monster MotorsportVolks Autos
Results 1 to 16 of 16
    mattyboy_82's Avatar
    Jul 2012
    Pontypool - south wales
    60
    Xenon light self levelling problem! PLEASE HELP :(
    As i posted earlier i had a problem with my xenon lights 2010 with DRL, they seem to dazzle people i thought they were too bright but case was the passenger light was too high! however just took it for a drive as earlier we plugged it into VCDS and is saidd there was a fault with the light range or something cant remember now but it came up with a fault, so anyway we tried to find the sensor that sorts the levelling out but couldnt find it! so any way we manually adjusted the lights by comparing the beam on a ruler and they same to match up however just now took it for a drive and the passenger side seems slightly better but the drivers side seems alot lower , i got the 2 L shapes going across but obviously the passenger is higher, now apparently usually when plugged into VCDS it will sort it out back to factory but it couldnt sort it! the lights go up and down fine when u first turn the lights but dont understand why VCDS couldnt sort it?? anyway should i take it to a MOT place so they can manually adjust it properly?? thanks all
    Lewis583's Avatar
    Mar 2010
    836
    There are 2 sensors. One on the Nearside front lower suspension arm and one on the rear( I would think on the offside, though i'm not 100% on the rear).
    If the rod hasn't come off one of the sensors, you could have a faulty sensor/other electrical fault in the circuit.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jul 2012
    60
    But the bloke checked earlier and couldn't find any sensors at all in the front and no signs that anything had fall off or broke that's where we were confused
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,165
    If car got factory xenon's fitted (should also have headlamp washers) then the sensor is located on the front nearside suspension attached to the wishbone. It's dead easy to see.
    My car had fault "Range control faulty" fixed with a new sensor. Easy pezi job, if wheel removed for better axis.
    In my case, no need for VCDS to re-calibrate.
    If sensor had fallen off, I'd say the 2pin plug should still be attached to wiring loom.
    Jul 2012
    60
    How much was the actual sensor to buy? Thanks
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    if it turns out you need the range unit drop me a pm ive got a 2010+ version for cheap
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    26,777
    You need to post up the actual fault, as we're just throwing ideas in the air atm, pointless changing anything without actually knowing the cause.
    Also do your research, when calibrating the beam with vcds, you have to set what is known as mot mode, then adjust them manually all whilst sitting on a flat surface namely mot bay.
    This has been discussed numerous times, so always do a search 1st.
    Also as per above, there are 2 sensors, 1 on front axle passenger side look behind the brake discs/suspension leg down low & 1 on rear passenger side hidden underneath which requires lifting car to get to safely & each has a 4 pin connector to them using 3 wires.
    This is of course if they're from factory as also mentioned above.
    If you've lowered the car at all or suspension work, then the arms could of snapped or you havnt done a calibration at the new height.
    Jul 2012
    60
    I have done a search !!! Was looking for hours thanks! But couldn't find a specific thread with the answer I needed. Well I haven't taken the wheel off but my mate turned the wheel full lock and couldn't see any sensor at all so we have assumed its bloody fallen off!
    26,777
    They dont just fall of, they're bolted on very well normally, rear has 5 bolts in total & front has 2 because its smaller, but very strong fixings usually.
    I would say you just need to get a torch in there & get underneath to see the area better, but as advised, 1st get the fault code as it may not even be this the issue.
    Jul 2012
    60
    All I know is it sais on the Vcds range control falty so god knows but my mate couldn't find any sensor at all there but we only turned the wheel full lock didn't take the wheel off
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    is your car a quattro?
    Mods
    Jul 2012
    60
    No mate , 1.6 tdi s line 2 wheel drive
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    the sensors are connected between the arms and the subframe they are in an elbow shape, we would need to see the vcds scan that was taken
    did you have your led xenons fitted or where they there from factory?
    Mods
    Jul 2012
    60
    Ye from factory mate with the washers built into front bumper if I can il try and get the code tonite gonna phone Audi see if I can get it done on warranty
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    should be no problem if it is the unit
    Mods
    26,777
    If its under 3 years old then get audi to fix.
  1. Self levelling headlights???? Please help
    By Hyborg in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2013, 19:50
  2. audi fueling and battery light problems please help
    By the jammy one in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th July 2010, 22:27
  3. LED warning light and alarm problem please help
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2010, 13:52
  4. Head light problem ...please help, anyone?
    By 10blazin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2010, 21:49
  5. S3 Instrument Cluster Problem - PLEASE HELP !
    By imported_G123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2004, 08:03
