mattyboy_82
As i posted earlier i had a problem with my xenon lights 2010 with DRL, they seem to dazzle people i thought they were too bright but case was the passenger light was too high! however just took it for a drive as earlier we plugged it into VCDS and is saidd there was a fault with the light range or something cant remember now but it came up with a fault, so anyway we tried to find the sensor that sorts the levelling out but couldnt find it! so any way we manually adjusted the lights by comparing the beam on a ruler and they same to match up however just now took it for a drive and the passenger side seems slightly better but the drivers side seems alot lower , i got the 2 L shapes going across but obviously the passenger is higher, now apparently usually when plugged into VCDS it will sort it out back to factory but it couldnt sort it! the lights go up and down fine when u first turn the lights but dont understand why VCDS couldnt sort it?? anyway should i take it to a MOT place so they can manually adjust it properly?? thanks all
