Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    Burkin's Avatar
    May 2012
    derby
    173
    Ease of fog light retrofit
    Hi I have a 1.6 a3 and it doesn't have fog lights and I was wondering how easy it is to fit them and how I would fit them?
    Any ideas?
    Nov 2008
    389
    What year is your A3?
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    27,038
    Depends on the electronic board fitted, but 90% of the time its compatible, as its a 1.6 I would hazard a guess its an 1.6 fsi so maybe original as in 03-06 ish?
    Need a loom, fogs, coding, fog area fitment available & grills, does help having some technical abilities tbh.
    Do you need them supplied/fitted?
    Burkin's Avatar
    May 2012
    derby
    173
    Nope it a 1.6i 2008 Pre face
    27,038
    Didnt know they did a 1.6 in 08 tbh, thought they'd phased them out, everydays a school day.
    Burkin's Avatar
    May 2012
    derby
    173
    It's early 08 so is in the 05-07 bracket
    Sep 2012
    Dunstable
    59
    Audi A3 8P fog light retrofit
    I have a 2006 1.6 8 valve and am thinking of the same mod so would appreciate any advice or pointing to a previous thread
    Nov 2008
    389
    What trim level is the car? Standard, SE - guessing standard otherwise would have come with fogs...
    Sep 2012
    Dunstable
    59
    Quote Originally Posted by phil_w View Post
    Its an SE
    Sep 2012
    20
    Re: Ease of fog light retrofit
    ive got an se and i was thinking of doing the same thing but do the fog lights and grills fit in an se's front bumper?
    sorry to hijack your thread by the way
    Nov 2008
    389
    Yep fogs and grilles fit - as per above - need fog lights, grilles, loom, new headlight switch with front fog setting, possibly an uprated Central Electronics Module (lowline from that era didn't support fogs) plus patience...
  1. Fog Light (front) retrofit
    By social_mogul in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2010, 16:11
  2. Need new fog light!
    By justin_1ss in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 19:50
  3. rear fog light
    By sllt1776 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2004, 00:45
  4. A4 fog lights fit on an S4???
    By qtip123 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2003, 14:19
  5. Lame O Fog lights
    By banjo_guru in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th September 2003, 18:04
