Sky InsuranceAH Fabrications
    Aug 2012
    Northumberland
    Help!! Horrible bearing whirling noise!
    Hi all!
    I have an A3 2.0tdi 2003, owned for 5 months now and couple months ago a whirling noise started. I have experience as a mechanic years ago but not enough to solve this problem. The "bearing like" grind seems to happen when applying the throttle over a crest or bumps @ 20mph+ however this does not happen around corners or on a flat straight. Only when the weight seems to lift off the wheels. I have checked for play in both front wheels but they are fine, i have had the wheels off checking for any rubbing marks or anything loose.. again fine. I have a feeling it could be something to do with one of the drive shafts but i have been told to go full lock in a circle both ways and listen for a clicking noise.. again it seems to be fine. Has anybody had a similar problem or could give me some advice please? Would be much appreciated, Thanks all, Tom.
    A3_Adam's Avatar
    Jul 2010
    Hertfordshire/Portsmouth
    62
    Not 100% certain but had a similar sort of noise on my 53 reg A3 when I lowered it. Turned out it was a large stone stuck between the rear of the brake disk and splash guard .
    Current: A3 2.0 TDI 140
    Mods: Facelift Front, Black Optics Grille, MY09 Rears, HnR lowering springs, Bilstein B4 shocks, Ipod Connection, RS4 Alloys, DTUK Tuning Box
    Link to Build Thread
    M25/South East Monthly Meets
    Aug 2012
    Northumberland
    Yeh i had a look for any obstructions.. only stripped the caliper etc on the one side but couldnt see anything. Its driving me crazy!! ..Nice facelift by the way, i have the split grill, drop grill looks far nicer!
  1. HELP!! What is this noise?
    By Quattro180 in forum Diesel forum
    Last Post: 1st February 2012, 13:14
  2. Help locating a Wobbling Noise - Driving me Nuts
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2011, 14:50
  3. Help needed. Strange metalic noise when releasing gas pedal.
    By amgad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2010, 23:07
  4. Help with tick tick noise from engine
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 17:33
  5. HELP WITH MY FRONT NOISE IN MY NEW AUDI S3!
    By awaissmann in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2009, 22:43
