Volks AutosChris Nott
Results 1 to 7 of 7
    luton
    234
    Power steering failure , j500 Advise needed!!!
    About a month ago my dreaded red steering wheel light came on and lost all power steering ,
    Since then I had the fault code read and it came back as j500 which I believe is the power steering module ,
    I went to gsf and got another rack but had no module on it ,but you can't buy these modules separate
    so my question is if I was to buy a 2 nd hand rack that has the module on are these interchange able or do I need one that matches my part number ?
    The number on my rack is 1k2423051AC
    any help much appreciated
    26,722
    I have a rack if you're interested that comes complete.
    Dec 2011
    41
    steering rack
    Hi Mate
    Have you still got the rack for sale?will it fit my audi a3 2004 2.0tdi? how much you wanting?
    think my car has same problem, steering light on, and really heavy steering, to the point its hard to move when stationary.
    26,722
    I do, send me an offer via PM & its actually of an 04 tdi & worked fine before removal.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,158
    Hi fella perhaps these guy may be able to help.
    BBA reman online catalogue
    Dec 2011
    41
    It won't let me pm u, tell me how much u want for it,seen them on eBay from £39 up to £150
    i don't know my part number,will this still work?
    luton
    234
    i brought a 3rd gen rack in the end with loom,had it fitted,
    works fine but has brought up the glow plug symbol flashing,
    scanned for fault codes and this come up internal control module
    p1640 fault code 18048
    eeprom error
    has anyone kindly got any pointers thanks dan
  1. Power steering failure
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2012, 16:50
  2. Checking Power Steering Fluid level!! Help needed asap!
    By scott_johnson in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2010, 08:24
  3. power steering rack recon place needed
    By a6george in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th September 2010, 19:58
  4. In need of URGENT HELP!!!! Power steering, and ticking noises....
    By Quattro-izy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2010, 10:49
  5. Power steering failure???
    By bobby_southward in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2010, 21:28
