Your in the wrong forum and a 1.8T will go to approx 190ish hp. Depends on the engine code really as the later ones had slightly different turbo's which would do the 210 mentioned.
an x reg is right on the cut over for drive by wire. Is it a 2001 model if so it may well be DBW in that case you can get more than 210 from them with a remap.
