EM TuningSky Insurance
Results 1 to 8 of 8
    Mar 2007
    Cambs
    471
    TDi ECU - plug and play or wishful thinking?
    Hi guys!
    Does anyone know if its as simple as swapping the box in terms of fitting another ECU?
    After my TDi 170 has now had a new injectors, harness, tandem pump, turbo, actuator, feed pipes, EGR and throttle body checked and cleaned, it still holds back one second on one second off in 4/5/6 above 3k revs, and apparently speaking to the previous owner the car has done this from new but Audi could not find the fault!
    In process of elimination im thinking could it now be the ECU as I was told this is the one thing that does not show up fault codes as shows all clear.
    I saw one on ebay for £200 and was thinking what at the chances I could get that and fit it and solves problems?
    Many thanks for any information
    CB
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Take it to big fish running ( John). My bothers car did it but the remap cured the issue !
    2.0 tdi 220 Quattro.....
    Bigfish tuning remap, S-line half Leather heated seats, Bose sounds, Elec' fold in heated mirrors, tyre pressure monitors, Charcoal roof linning, Mfsw,phone prep, 18" Speedlines, Dual climate, total open/closure remote windows,L.e.d rear lights, Ch/Lh lights,puddle lights,Cruise Ctrl, Ambient Interior lighting, footwell lights & it's a Quattro......
    Mar 2007
    Cambs
    471
    Really? wow, you have the exact same car as me
    So was hesitating as described? I can only think the ECU had a fault from new then, so a remap clears any faults with new software?
    27,072
    ECU will need coding with immo, so its not exactly pnp & must be exact same part number.
    Cant recall but manual or auto?
    Mar 2007
    Cambs
    471
    Its a manual mate, how do I tell which engine type mine is? I keep seeing BKD I think, mine is the 2.0 TDi 170 Quattro March 2008?
    Also is it possible for Audi, or someone who maps cars, to be able to tell if the ECU has a fault?
    Jun 2011
    Wellingborough
    1,168
    BKD is 140.
    BNM is 170.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    27,072
    As he said
    Best bet is to reflash the ecu with stock firmware at audi & see what occurs, only takes 30 minutes tops with road testing.
    Mar 2007
    Cambs
    471
    Ok cheers, that is, once I can get it started, GRRRR, FFS!
    Just went to car to move it as sat there since i drove it back Friday from them, turned over and and over and over, i know diesels do not do this! It did also flash a message on the dash very quickly but didnt catch it, again, GRRRR!
    Ill try it again in a bit but this is reaaaaaaaly starting to pee me off now
  1. A3 2.0 TDI PD remap problem with plug and play
    By Charles Tait in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2012, 16:46
  2. Plug and Play Tuning for the new 3.0 TDi 204 and 245ps
    By ABYSS in forum Diesel Tuning UK
    Last Post: 7th May 2012, 15:54
  3. plug and play chips
    By Budgie21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 08:42
  4. Replies: 4
    Last Post: 17th November 2008, 13:40
  5. Xenons are plug and play!
    By AkoyaMike in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2006, 11:01
