Volks AutosMonster Motorsport
Results 1 to 11 of 11
Thread: DIY Oil Change
    Bailey's Avatar
    Jun 2009
    Alton, Staffordshire
    247
    DIY Oil Change
    Hi there people,
    I have seen a few threads and guides on the forum in order to do a DIY oil change so I am considering doing it myself.
    I have a 2005 2.0 TDI so I am just going to ask a few questions to see if you guys know.
    Is it straight forward to do?
    I have got this oil in mind to use so will this be ok?
    Castrol Audi Edge Fully Synthetic 5W30 Engine Oil (4 Litre) | Euro Car Parts UK’s No.1 Car Parts Retailer
    Will this oil filter be ok?
    Hengst Audi | Euro Car Parts UK’s No.1 Car Parts Retailer
    Ok so here goes, I think this is how I will do it so please correct me if I am wrong?
    1 - Jack the car up onto axle stands ( as I dont have a ramp or pit )
    2 - Get something to catch the oil when it is being drained.
    3 - Remove protective cover to reveal the sump and lower engine.
    4 - Release / unscrew the sump plug and let the oil fully drain out.
    5 - Take off the old oil filter and replace with new one once fully drained.
    6 - screw up the sump plug again.
    7 - Fill up with oil again, I have heard the oil capacity is 3.7L???
    8 - Screw oil cap back on
    Is this correct? Also do I need any special tools in order to do this?
    Also how do you reset the service indicator on the DIS as it is coming up it needs a service?
    Bailey
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Think oil capacity may be more like 4.5 litres.
    I'd put the filter back on before filling with engine oil.
    Fill when car is on level ground.
    Some cars may use a hex key for the sump plug.
    Start engine and looks for leaks.
    Car hand book gives oil capacities and how to reset service indicator.
    If you are worried, take it to a fast fit place to have the oil change. Think they'll charge about £35. There was a posting on here about that a few days ago.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    It's just easier to get an oil change done by someone to be honest. You can supply the oil though.... You won't have the hassle of getting rid of the old oil then either.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    c_w
    1,061
    That capacity you quote is possibly for the 1.9 which uses less oil. I buy 5l bottls and generally use all but a small amount of it.
    Fiddliest bit is removing the oil filter as there's some bits in the way.
    Bailey's Avatar
    Jun 2009
    247
    Thanks guys,
    I might just take it somewhere to be done to be on the safe side, I have got my car booked into Midland VW for a Cam belt change Saturday and they said they would do it for me as I will buy the parts and just charge me labour.
    I did want to attempt it though but it would be easier just getting them to do it.
    Bailey
    May 2011
    Portsmouth
    397
    Just get the garage to do it. Sometimes the oil filter is stuck on like a b***h and you need a oil ratchet strap to remove it (alternatively you just ram a screwdriver through and unscrew it that way. In no way ideal but worked when I was 17 on an old golf!!!
    I peronsally do my oil changes because I never have time to get a garage to do it
    In gear ready for the off!
    Jan 2012
    Northwest
    Bailey, just go ahead and do the oil change straight forward job, you may want to get a new sump plug from Audi as I think the seal on the plug is built in. The oil capacity is about 3.8 ltrs when you change the oil filter as well, the oil filter on the 2.0 tdi is a slip on filter cartridge as per your parts list. The oil filter is accessible by unscrewing the black plastic cover with hexagon flats on it anticlockwise direction, don't use a screwdriver as previously advised as you will require the black plastic filter cover again on reassembly!!! Also put a little fresh oil around the o ring in the filter cover to help it seal and just nip it up as you will crack it if up tighten it too much.
    Mar 2011
    Cleveland
    965
    Treat yourself to one of these:-
    Quick Valve UK - supplying Fumoto oil drain valves
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    DIY Oil Change
    Just done a DIY oil change on my gf's A3, used the code OILSPILL30 to get 30% off oil at euro car parts, oil and filter for 20 bucks which is a bargain, as mentioned above only extra thing is new sump plug from audi
    Mar 2011
    67
    Quote Originally Posted by fangio View Post
    Not sure I'd trust one of those?
    Mar 2011
    Cleveland
    965
    Read up on it!
  1. DIY Oil Change A3 TDI
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2014, 18:27
  2. Oil change 2.0 tdi?? DIY or Dealer? 10k or 20K?
    By mx_rab in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2011, 19:45
  3. DIY S3 Oil Change
    By scoobyra in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2010, 06:18
  4. DIY Oil change.
    By MURRAYS444 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2010, 17:03
  5. Auto Gearbox oil change at 70K ? / DIY methods
    By RogerTDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd October 2006, 08:54
