Volks AutosChris Nott
Results 1 to 10 of 10
    Richh999's Avatar
    Dec 2010
    Beds/Cambs, Bristol Uni
    155
    344mm Brake Calipers with 345mm Discs
    Hi guys.
    Got a great offer on MK4 R32 brakes so I was just wondering if...
    I know that the R32 MK4 brakes a 5x100 334mm discs however I was just wondering whether the calipers would fit on the 8p and whether 345mm discs would then fit in them or should I just find some other brakes, get the 334mm discs redrilled?
    Will the calipers fit with other discs or not?
    Audi A3 2.0TDI Black Remapped, with S3 Exterior, Half Leathers, 18" Alloys, Xenons, Tints, Cruise, Armrest, FBMFSW and RNS-E with BT...
    Have VCDS either around bristol, term time, or beds/cambs during holidays/some weekends..
    16V Classic Mini Mid Engined RWD 1.8VVC http://www.16vminiclub.com/forums/sh...ad.php?t=28324
    K13 ASJ's Avatar
    Aug 2011
    Buckie (north east scotland)
    176
    I'm no expert in brakes but i would say no they wont fit the larger discs. i also dont think the mk4 calipers would fit your 8p as if they were a straight fit loads of the mk4 golf folk would be going for s3 callipers...
    I would suggest save a bit more cash and go for the s3 set up
    thebluefox's Avatar
    Jul 2012
    Leicester
    152
    Fairly sure the won't fit, as is my understanding it's not really a dimension issue, and more so just to do with the fact the bolt holes just won't match up on the carriers.
    I've got a mk4 Golf at the moment and I've not seen any running 8P S3 brakes straight out of the box. All our upgrades come from either the R32, or mk4 platform Cupra R.
    Richh999's Avatar
    Dec 2010
    155
    Thanks for the responses guys..
    Well the discs themselves are actually a different profile and if they were drilled to fit the hub PCD the calipers would then need spacers to fit the hub and then need riduclous wheels for clearance.. The MK5 hubs are further out than the mk4 for what I can see..
    The carrier bolts however look to be a similar distance though so maybe if 345mm disc were turned down to the smaller size they may fit?? Or carrier 'extenders' were fabriacted to move the caliper further out they may work.. hmmm.. Maybe a bit too much work for a free brake upgrade from my 288mm but can fabricate most things as I'm handy with tools..
    Saving up for hybrid turbo as mines going to die soon but want to do brakes first without spending too much really..
    Does anyone have a spec sheet with the dimensions for the S3 brake discs and calipers??? Thanks
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,551
    Hi rich give me a shout if you want my s3 brakes..
    chris1988brown's Avatar
    middlesbrough
    578
    100% won't fit mate s3 brakes are a awesome upgrade tho
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    Richh999's Avatar
    Dec 2010
    155
    So I've been looking into getting a proper S3 brake setup however I was bored today and I'm not the sort of person who think inside the box, or out side it really.. More the kind that sees a box, picks it up, tears it to pieces and burns them and then thinks so yeah..
    I looked at how hard it would be to fit the MK4 brakes.. Well, from what I can tell not too hard with a piece fabricated..
    The 334mm discs and caliper inside my wheel.. mmmm..
    I removed my old brakes and then offered up the larger caliper..
    put a 280mm disc on for size.. The 334 discs are completly wrong and wouldn't work..
    Postion of mounting holes..
    Down the inside..
    measured from the edge of the 280mm disc to the caliper is around 40mm..
    This means I could fit upto a 360mm ish size disc however obviously the pads wouldn't cover it however it would be similar effect as 288mm to 312mm upgrade as the pads aren't changed???
    By fabriacting something like this I could attach the caliper inline with the hub..
    Now modifying the carrier slightly could move a caliper inwards slightly onto 245mm discs and thus it may work or I could use larger discs..
    Love this picture too..
    middlesbrough
    578
    Really bouldnt bother mate will b a total chew on and ordering parts eg disc n pads would be a pain in the future or for owner after your if not put back to standard
    MY PROGRESS THREAD
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,793
    Quote Originally Posted by chris1988brown View Post
    (see red)just reminded me of this guy haha
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Back in circa 2004 I had a classic shaped Impreza Turbo and I wanted to fit the gold brembos from the newer shaped STi to it.
    The fronts went straight on but the rears were a different story.
    Several people told me it couldn't be done......but they were wrong!
    I set about measuring the hub/disc/calliper to fabricate an adapter bracket.
    A few years later you were able to buy an off-the-shelf kit but it proves it can be done.
    Shown below were the final results(yes I know the calliper is upside down in one of the pics)
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
  1. S3 front brake calipers and discs on A3 2.0TDi
    By SimonAshley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2011, 03:59
  2. ATE 4 pot Calipers With Disc's - What They Worth?
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2009, 09:04
  3. URGENT: 345MM BRAKE CALIPER HELP - front clip!
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2009, 09:26
  4. Brake Caliper Paint Kit
    By RevoKev in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2005, 10:17
  5. Tool for winding brake calipers?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2005, 15:31
