Volks AutosChris Nott
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Greeny233
Thread: Wheel Alignment - How long after replacing suspension?
    TimG's Avatar
    Feb 2004
    South Coast
    932
    What's the general consensus on how much mileage to do before getting an alignment done after changing over suspension? I know from experience it takes a while to settle and the car can drop quite a bit further in this time. I normally just kinda leave it for 'a while' but what are other peoples thoughts on it?
    Tim
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    I've always left it till the suspension has settled in. As you said it drops more once its settled. Maybe 2-4weeks?
    Mine needs doing buy cant find any one that can do it for me
    Dark Vader Half sibling - MyThread
    TimG's Avatar
    Feb 2004
    South Coast
    932
    I used to just get a simple tracking done as front camber cant be adjusted on most VAG platforms and the increased - camber on the rears is usually helpful for clearance! Problem is if your tyres are actually level with the arch or tucking normal old school garages cant get the tool on that hangs on the tyres!
    Because of this I had to find a centre with a Hunter 4 wheel system where they attach the device directly to the rim. They still only adjust the front toe in the £55 charge though and its extra if you want the rears done (place I went to in Brighton anyway).
    If anyone has any different experiences with aligning a 'low' car please share them!
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Cheers for that Tim. Will see if i can find some one local-ish with the "hunter 4 wheel system".
    will let you know how i get on lol may have to travel to get it done
    Greeny233's Avatar
    Mar 2011
    Llangollen
    688
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Get it done straight away, the tracking could go miles out after fitting new suspension and driving about could ruin your tyres and handling.
    The suspension will settle far less than the initial drop so not much point in waiting for it to settle.
    RedDejavu likes this.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    TimG's Avatar
    Feb 2004
    South Coast
    932
    That's a fair comment. However I've gone from having one brand of coilovers to another. The car was all tracked after the first set were fitted 18 months ago. I have actually only gone a 'bit' lower than I was before.
    The reason I know the alignment is out is clearly its all been taken apart down there with the change of struts etc, but also the steering wheel is no longer central which annoys the hell out of me!
    TimG's Avatar
    Feb 2004
    South Coast
    932
    On that note, how does the steering wheel end up off centre anyway? The tie rods aren't touched so how does unbolting the hub & changing to a different strut affect the steering wheel position? Can't quite get my head around it
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Quote Originally Posted by TimG View Post
    That's a fair comment. However I've gone from having one brand as coilovers to another. The car was all tracked after the first set were fitted 18 months ago. I have actually only gone a 'bit' lower than I was before.
    My steering wheel slightly off where i had new hubs, brakes fitted at the same time as the coilovers. And the passenger front hub was buckled slightly out a few mm (seller didnt tell me it was damaged Ar$£ h0le ) Couldnt get a new hub till monday and this happened on friday evening. By the time they fitted the new hub my steering wheel was slightly off :| Does my heading and as said will wear your tyres done. Never had this issue before with the other two sets only when that damaged part was fitted. Hope you get it sorted asap mate
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Contacted these guys Tyre Alignment in Southampton | Laser Wheel Alignment in Winchester this afternoon on recommendation from some threads on Pistonheads. The guy sounded really knowledgeable and if I took the car in he'd hook it all up and see what was going on for free. Then if I wanted, set it up how I wanted for around £40 and then I could go back in a week or so to check it again (if it had settled/moved etc), again free of charge.
    That cost was just for the front end adjustment mind, but I said the rears are spot on fitment wise for me already, albeit a little more camber than factory!
    He also said its far from straightforward just doing the fronts, if the rears are out of factory spec as its all related, but he'd sort it. I said tbh I just want my steering wheel straight and to avoid tyre wear rather than a fancy fast road set up etc.
    The other thing he said was to get it done asap after lowering as once tyres wear unevenly at all, they continue this way, which will likely have a bigger impact than waiting for suspension to 'settle'.
    Anyhow, I'll report back after I've been there.
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Cheers Tim
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    I think there's a few places that'd be happy to check alignment they'd sorted once the car had settled, and make any final adjustments free of charge. Or if not, there should be. That's what I'll be looking for once I get coils on (didn't do any alignments after putting on the springs, probably should have).
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
  1. How long does it take to replace wheel bearings on a B5 Quattro?
    By Tom_B in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2012, 18:31
  2. Vagcom steering re-align/calibrate after a 4 wheel alignment?
    By myke in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th April 2010, 00:41
  3. How long to fit new suspension?
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2009, 06:06
  4. How much to replace wheel bearing??
    By Keefo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2009, 19:07
  5. When u took dleivery and how long after build date /?
    By madalex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2007, 12:54
