AH FabricationsVolks Autos
Results 1 to 7 of 7
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Does this sound like a leak or a failing turbo?
    After getting to the bottom of my losing water problem (turned out the rad was visibly leaking, luckily) I've now got a new problem;
    I've started getting quite a bit of white/grey smoke that smells like diesel fumes. This happens randomly.
    - Sometimes it smokes a lot on start up, sometimes it starts without so much as a waft of smoke.
    - It doesn't matter if it's hot or cold.
    - It's at it's worst when pulling away in 1st gear. In fact, when driving it hard in the higher gears it hardly seems to smoke at all.
    - I'm not losing any water or oil.
    - Besides the smoke, the car runs perfectly and I haven't noticed any loss of power.
    - VCDS doesn't pick up any fault codes.
    While Audi were changing the radiator about 500 miles ago, I also got an oil change service done. I then bought the air filter and diesel filter from them and fitted those myself, so all the filters are new and genuine.
    (They also gave me a free sump after striping the thread, but that's another story).
    I did notice the boost pipes under the front drivers side of the engine bay are oily at the joints, but Audi didn't seem concerned about this.
    Do these symptoms sound like a boost or vacuum leak, or do they sound like the turbo is on it's way out?
    If it was the turbo, then wouldn't it happen more at higher revs and full boost, rather than when pulling away normally in 1st gear?
    Does the engine twist more when pulling away in 1st gear, because I'm wondering if it's opening up a split pipe or joint under these conditions?
    I'm baffled, please can anyone offer any advice?
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    While going through hundreds of search results I came across a similar problem people have been having with the A6 2.5 TDi. The conclusions they came to were either a blocked breather (I've not got the pressure when removing the filler cap) or a crudded up and sticking EGR.
    I know sort of know how an EGR works, but I'm not sure of the times it would be open/closed in relation to my smoking issue. Also, how does a stuck EGR cause white smoke?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    In first instance I would say check the joints in the boost pipes as the oil is a sign of an air leak, not sure about the egr but I would also like to know the answer to that one as I sometimes feel a little under power in mine although I recently changed the boost and intercooler pipe.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    May 2012
    596
    Im not sure how exactly it causes white smoke...but a stuck EGR valve will chuck some utter crap out the back. could well be that yours is sticking either way if its intermittent. My egr valve snapped off and lodged itself in the egr unit luckily and not in the pipes, but when you hit the gas it just leaves the road behind in a dense fog lol!
    Have it cleaned it may well be the issue
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition 220bhp, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights. remap/diverter valve soon
    Gone - 2005 B7 A4 SE TDI Avant 2.0 140bhp
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    When you say yours left the road behind in a dense fog Av4nt, what colour was the smoke?
    I've also just noticed that my oil level was a bit over the maximum mark, even though it was Audi that did the oil change. I wonder of that is making matters worse.
    I've noticed that mine only really smokes when pulling away up to 1500rpm and then it's clear.
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    Definetly worth cleaning the egr out ago with shudder valve which is attached, te leaking boost pipe are common, don't bother buying new seals off Audi, will cost you £12 for nothing, just get some ptfe tape and pack the washer, I've done this on mine, doesn't leak abit
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Quote Originally Posted by Jord View Post
    Thanks for the advice Jord. I'll just get the ones for the egr then.
  1. Does this sound like water pump failure?
    By waynos in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 10:11
  2. Does this sound like coil pack-packs?
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2010, 21:33
  3. Does this sound like my MAF sensor?
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2009, 16:38
  4. Does This Sound Like My Turbo's Dying!
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2009, 20:03
  5. Does this sound like a coilpack problem?
    By christinho in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 20:17
Tags for this Thread
