EM TuningJMB Retrofits
Results 1 to 8 of 8
    BigWillyStyle's Avatar
    Aug 2012
    566
    Could maybe a Remap solve my engine problems.....?
    In my other threads i've posted i've stated that my auto S-Line 2.0 TDI has problems starting, more so when engine temp is at half way, stalling (Unusual considering its an auto),revs dropping and increasing in low gears making it 'jump' and changing down in gears roughly when i brake like its over revving.
    I was wondering could this be something to do with fuelling or an ECU?
    Just trying to think of everything to solve the problem because im pretty damn worried about it!
    P.S i've been told about the Mechatronic unit going t*ts up but im trying not to think about that
    jaydav2306's Avatar
    a REMAP will only make the problems worse and fail on a bigger scale, it's not the answer if you engine is not running 100%
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    I agree ^^^
    an engine should only be mapped when it's healthy.
    its a bit like tearing a leg off a dog then telling him to run faster and with better technique.
    Just isn't gonna happen.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Aug 2012
    566
    Quote Originally Posted by jaydav2306 View Post
    Quote Originally Posted by mjr901 View Post
    I agree ^^^
    B*lls!
    Was kinda hoping this would solve the problem! Its been on a diagnostic machine but no faults.
    Going to my mates garage again on Sat so hopefully he will have an idea, if not, im screwed!
    jaydav2306's Avatar
    A cheap place to start would be change the plugs, have the MAF and clean that or replace if you can find a cheap one, dosent sound ECU or Mechatronic related to me
    Aug 2012
    566
    If it was the ECU or Mechatronic unit i'd assume something would have came up on the Diagnostic machine?
    thebluefox's Avatar
    Jul 2012
    Leicester
    152
    Echo what the others have said, only map it when its running smoothly.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Diagnostic machines are great, but they aren't the be all and end all. I rely on the live data streams and knowing how to interpret it for diagnostics
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
  2. Diesel Engine problems
    By sinbadfury in forum Diesel forum
    Last Post: 16th May 2006, 15:26
  3. 2000 A6 2.8 Quattro engine problem
    By bullcell in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th August 2005, 23:02
  4. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
  5. Engine Problem - 2.6 V6 - possibly ECU Fault -
    By imported_k15hvc in forum Classic Audi Forum
    Last Post: 11th July 2004, 21:40
