EM TuningAH Fabrications
Results 1 to 12 of 12
    Feb 2012
    Kirriemuir, Scotland
    33
    Revo map without using a rolling road?
    Hi everyone,
    I have inquired about a Revo stage 1 map for my 8p2 S3, I asked if the car would be dyno'd before and after to see if the car was operating within perameters but he has replyed saying they prefer to do it on the road under real load, atmospheric conditions etc, is this a common practice as i always thought it was the rolling road option?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    mine was done that way..probably it's better because those are real conditions.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Dec 2011
    237
    They can set it up better on the road as that where your be driving it mate more accurate readings
    Feb 2012
    33
    It does make sense to me but just read threads on here people saying rolling road, plots before and after etc etc, one thing thats is really putting me off is the fact it can highlight firing problems and clutch slipping etc! my car has done just over 60000 so was wondering if a new clutch would be advisable?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    i'm runing now almost 40 000 km's and it's 30 000 on remaps, first i had stage 2, now i switched to revo stage 2+ for 5 000 km's, and i had a ocassional clutch slip, but it depends how you drive it. your clutch will be fine if you don't torment it. if you don't do 0-60 launches, accelerate hard from 2000 rpms in higher gears, clutch will be fine. you should probably start saving for a new clutch anyways.
    revo remaps are really great. had issues with old stage 2 map but with revo not a single one.
    Feb 2012
    33
    LOL I have the credit card stashed away for when the clutch needs doing, i never looked into how much one was until after i had bought my S3 and i though oh ****! Audi know how to charge for parts/labour thats for sure!
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Quote Originally Posted by MarkMS3 View Post
    after remap you should go for a stronger/aftermarket one :D
    thebluefox's Avatar
    Jul 2012
    Leicester
    152
    When my Golf was done, it was done on a RR before and after in controlled conditions, then road tested. Of you ask me, the only place to thrash a car safely is on a track or a rolling road. Doing it this way allows for lots more runs and fine tuning.
    IMO, anyway.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Quote Originally Posted by thebluefox View Post
    IMO, anyway.
    that's the best way.
    gixerson's Avatar
    Jul 2012
    Athens, Greece
    124
    IMO, anyway.
    Agree.
    I have tuned cars on the road, but it takes a LOT longer and even then you still have areas on the map that your going to miss.
    After weeks of datalogging and tuning i thought my cars previous tune was pretty much perfect, we then left on hols only for the car to struggle at certain sections of a hill, simply because i had been able to recreate these loads on my local roads when tuning.
    On a rolling road you can adjust the load and keep a consistent throttle and/or RPM point.
    It is better to tune on a rolling road with a road test after.
    Some shops don't use RR's as they are expensive and and a fair bit of money, room and time for proper training needs dedicating to install, run and maintain.
    For me personally i would not pay for a shop to tune my car if they didn't have a rolling road.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,423
    Mine has always been set up using both.....RR first,then a good long session on the road.
    thebluefox's Avatar
    Jul 2012
    Leicester
    152
    Quote Originally Posted by gixerson View Post
    Me neither. The place I had mine done at RR'd it before, went over everything with a fine tooth comb to check boost leaks etc. It was then mapped on a few runs and then checked completely again. I'd like to see someone give the same time and attention to a car when its on the public road.
  1. REVO kicks ass at Regal rolling road day!
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th October 2008, 22:07
  2. Re-map Rolling road shootout???
    By Fat Tony in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2007, 18:25
  3. Revo and Rolling road.
    By Ricco in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2006, 14:33
  4. Replies: 1
    Last Post: 5th June 2005, 19:12
  5. Detecting problems using Rolling Road
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2004, 20:01
