Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By rickypj
  • 1 Post By MTRL
Thread: Advice on dangerous work done on my car.
    Feb 2011
    Coventry
    59
    Angry Advice on dangerous work done on my car.
    Hi Guys,
    I recently had a cam belt and water pump replaced on my car by a local AUDI/VW specialists. Today i was under the car replacing the Diverter Valve when i noticed that the engine and engine mount had a massive gap between them and the lower bolt was hanging out and the top two were obviously loose. I realise that if the bolts had droped out so would my engine.
    Sorry about the poor pic.
    I managed to get the lower bolt done back up but theres no way of getting to the top two without dropping the mount off and jacking up the engine.
    Qustion 1, do you think the bolts might now be bent/weakend from the load they have been under?
    Question 2, how shall i go about dealing with the company that did the work. i.e compensation, getting them to recheck everything?
    I dont really want them to touch the car again.
    Im pretty angry about it as my mrs has been driving it daily for the past 4 months with my 1 yr old daughter inside and i know that if it had gone wrong it would have caused a major accident.
    Thanks for any help or advice you may have.
    Audi A3 2.0TFSI S line DSG SB BLUEFIN
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Thats bad!! Is it just me or does that look cross threaded!?
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    Feb 2011
    Coventry
    59
    Quote Originally Posted by S3_NOOB View Post
    It wasnt cross threaded as it wound in niceley. just the muppet that did it hadnt tightend them up.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,980
    the engine wouldnt have fallen out
    what did the audi/vw specialists do to the car for you ?
    Feb 2011
    Coventry
    59
    Cam belt and water pump. If the bolts had dropped out or sheared then the engine would have pretty much dropped out. Aux belt would have hit the chassis leg and snapped. PAS might have packed up. Who knows what may have happened at 70mph
    bez101's Avatar
    Jul 2008
    7,980
    didnt realise you had to take the mount off to do the belts
    but depending on how long ago they did the work its gona be hard to prove they did it
    Feb 2011
    Coventry
    59
    Yeah you have to move the monitor as the belt runs trough the centre of the 3 bolting points. Not sure if I should just leave it and take it as a lesson learnt not to let anyone else that i don't know or trust work on my car.
    mozza1202 likes this.
    Feb 2011
    Coventry
    59
    Just so you all know who to avoid its.. VolkswagenAudi specialist..in Coventry on Longford road.
    bez101's Avatar
    Jul 2008
    7,980
    i just think it would be hard to prove them at fault
    might be worth haveing a work with them tho
    as for sure the gaffer will **** the bloke that worked on it
    Feb 2011
    Coventry
    59
    Quote Originally Posted by rickypj View Post
    Mount not monitor. Haha😊
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Jesus christ not again. They are the same guys I used to do my cambelt.
    Month or so after they did my engine literally dropped through the bottom of the car when pulling off from the lights.
    I phoned them up and told them what had happened and they picked my car up to inspect it to see if if was their fault.
    They didnt admit guilt but said they were able to fix everything under parts warranty.
    The bolts are stretch bolts and should only be used once, so if they are the same bolts as before then they are not following Audi's guidelines.
    Not 100% sure what they did to mine to **** it up but I think they must have left a bolt out.
    Lucky I was only doing about 5mph when it dropped.
    Id get back in touch with them and tell them you dont think they have secured the mount back correctlly.
    They will say that they will pick it up to check it out, if its something they have done then they will fix it for free but if not then they will try and charge you for pick up and inspection. Couple of hundred quid.
    akash_sky1 likes this.
    ....................I'll make a build thread one day.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,113
    So you recommend them to do engine coversions then? Looks like they are great at dropping engines out
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Jay.Ing's Avatar
    Jun 2008
    Southport
    227
    I would go in with the picture you have and ask to speak to the quality manager! They will soon poop themselves when you ask for him! Explain to him what you have found and see what he says/offers. I wouldnt just leave it as from what MTRL has says this does need highlighting again, we dont want this happening again and someones pride and joy getting distoyed, not to mention the occupents getting hurt!
    2012 A3 Ibis White SportBack Black Edition 140
    Mods so far: H&R 50mm, RNS-E, Cruise control, Interior OEM LED mood light, OEM LED number plate lights, OEM LED Puddle lights, OEM LED Footwell Lights, tear drop wiping, Beep confirm on close, pressed plates, HHA & TPMS.
    Mods to come:light/rain sensor (In progress), and so on........
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    Chugger
    North Devon
    2,716
    Iv had this happen before on a previous golf, engine didn't fall out but it did drop massively on one side. Mine also went while going slow. Still drove though
    **** luck and lesson learnt, I would take it to them to sort it and never use them again, as they obviously like to rush a job.
    57 A3 2.0 TDI Sportback (140)
    _G_
    _G_'s Avatar
    Jul 2011
    869
    up in cov today as mate takes care of my car... have recommended him to a few people on here and no complaints so far... burbages lane, opposite the ricoh... anyhow...
    to think that i actually thought about using that garage for a mechatronic rebuild once! sheesh! glad i didnt... the consumer law states that they need to put it right.. once they have then never see them again.
    The Governor's Avatar
    Mar 2012
    Southampton
    430
    I guess the question is, are they really capable of putting it right?
    Feb 2011
    Coventry
    59
    Quote Originally Posted by The Governor View Post
    Thats what ive been asking myself as well. I think im just going to check it all myself this afternoon. Its just ****e when ive payed money for it to be done and ive got to put it right. I knew i should have done the job myself in the first place as im more than capable but i didnt have the time with work/baby/2 step kids and a wedding to sort. I was a tech in dealerships for 10 yrs and a VW tech for 4yrs and i know what corners get cut in a dealership, so i can only imagine how bad some indipendant places could be. Ive def learnt my lesson not to let any other muppets touch my cars. I know not everyone is the same and i know there are some very good places out there but who knows where!
    May 2012
    Solihull
    73
    Midland VW in Cannock are very good from what I hear. That's where I'm going to take mine.
    Apr 2012
    N. Wales, LL22
    1,224
    ask to see the calibration certificate for his torque wrench
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Feb 2011
    Coventry
    59
    Wrote them an email this afternoon explaining my dissatisfaction with them. 😊 they rang me 10 mins later saying that although they are not admitting they are at fault they will pick the car up and replace the bolts and check it over as a good will gesture. Lol. So hopefully it should all be sorted and now we all know where not to go for a cam belt.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,071
    Glad you sorted it mate.. Good job and glad you spotted it before something bad happened.
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Feb 2011
    Coventry
    59
    Quote Originally Posted by JamesO View Post
    Thanks mate. I'm glad to. Still pee'd off tho.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,071
    I can well imagine u would be ****ers but at least you spotted it I've got two kids and one on route and would be ripping heads off
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    On a positive note, they did do a bang tidy job of fixing it.
    The guy who dealt with the issue was very good, cant remember his name think it was Andy. Just said as its all covered under parts warranty, "dont worry, leave it with me, i'll get it sorted." I was preparing the arguement that I would take to court if he hadn't have said that.
    It was a bit of a mess as you can imagine, and I was turning grey worrying about what id get back, Would it ever be the same?!
    Couple of stress filled days later car was waiting on my drive when I got home with shiny new engine bits. Even supplied new mounts!
    Would never tell anything happened.
    I was two minds about them, had a terrible experience and would be ripping their reputation to bits if it wasn't for how they handelled it.
    I would have given them a second chance untill I saw that it has happened again. Its a shame.
  1. Few works done on the Car
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2009, 16:49
  2. Any work done from Hazzydayz?
    By drnutta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2009, 15:20
  3. Is anyone thinking of having work done by Hazzydayz nr Manchester?
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd September 2009, 22:20
  4. What mods have you done to your car/engine?
    By K7ERG in forum Other Brands & Models
    Last Post: 1st October 2007, 19:50
  5. Should I get this work done on my 1996 A6?
    By cble8869 in forum Classic Audi Forum
    Last Post: 12th December 2003, 16:42
