AH FabricationsJMB Retrofits
Results 1 to 9 of 9
    Jul 2012
    44
    starting problem when warm
    my a3 2.0 tdi 2005 54 reg,has a problem starting when it gets warm its fine when cold fires up straight away but when its gets warm it takes a few seconds to start up.
    i havent been able to scan it as i dont have vagcom.
    just need your help on this please guys and girls.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    its a weak battery,check your coolant sensor readings when the temp of the car is half way (normal operating temp) the reading of the sensor should be above 80 check via vcds (measuring blocks) or defo a starter motor issue as they suffer from heatsoak from the gearbox and dont spin fast enough(even though you might think it does)
    Full leather/19"wheels/cruise/
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    9 times out of 10. starter motor.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jul 2012
    44
    Cant be the battery its brand new,so its one of two things then temp sensor or the starter motor.
    But it starts first all the time with no problems so will it be starter motor i would of thought if the motor was on its way out it would affect it on cold start aswell.
    Fossie
    Rhubarb Triangle
    3,969
    mjr901 is dead right. Starter motor is a common fault on BKD engines and mainly appears when hot starting. The fuel mixture is different when hot and requires more cranking effort than when cold.
    Do a search and you will finds loads of threads on the subject, just about all of which end up with a new starter motor
    Jul 2012
    44
    Damn o well does sound like a new starter then.
    jsosic's Avatar
    Mar 2011
    Zagreb, Croatia, Croatia
    172
    Quote Originally Posted by SHAKEY LFC View Post
    Please report back after you fix the issue... TY
    AudiMafia's Avatar
    Apr 2009
    London
    403
    ive got the same issue, let us know if u change the starter motor hope that solves it
    A3 8P 2.0TDI 140 Sport | Blue | Full Leather Heated Seat | BOSE | 6 Disc Changer | None Smoking Pack | | Nav | Xenons |
    Mods | 18" Rotiform Staggered | Tinted Windows | S3 Spoiler | 2009 S-Line t Rear | Front Chin Spoiler | Wind Deflectors | Re-Map |
    | MY11 Lights | S3 Side Skirts | Private Number Plate | Milltek Exhaust | S Line Gear knob
    Aug 2012
    Chris
    I have similar issue, but it's not too bad yet. Let us know how you get on.
  1. audi S3 starting problem (when warmed up)
    By russelj80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2012, 22:29
  2. APY Starting problem when warm
    By LordNelson in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2010, 09:58
  3. S4 problems starting when warm
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2010, 14:52
  4. 1998 S4 warm starting problem? HELP!
    By myfirsts4 in forum General Technical / How To
    Last Post: 15th July 2007, 11:19
  5. 1.9 tdi (1997) warm start problem
    By markf497 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2006, 17:20
