AH FabricationsBadger5
Results 1 to 27 of 27
    May 2012
    Carlisle
    296
    Fitted S3 brakes to my 2011 BE
    Fitted front S3 brakes last night along with stainless steel hoses, they seem to bleed up fine but then driving there's no pedal until you pump it a few times then the pedal comes back. then after a few minutes of not pressing the pedal its gone again. I Bled it up again this morning to no joy still. I've even tried black bleeding them still not joy.
    Anyone had the same problems or know why this is happening. there appears to be not leaks and the callipers i bought were recondition from the guy i bought them off.
    Jamie
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Did you not change the master cylinder to match?
    S3 Brake Master Cylinder upgrade
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    May 2012
    Carlisle
    296
    Dont need to as im only fitting standard S3 brakes was told dont need to upgrade untill you move to the RS3 set up
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Bigger piston so your going to notice a slight increase in travel.
    My mate fitted S3 calipers to his ED30(it has the bigger master cylinder) and still noticed an increased pedal travel.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    May 2012
    Carlisle
    296
    The brake don't work on first press of pedal at all can't be master cylinder problem to me
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    try a vacuum bleeder if you havent already, makes life alot easier.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by crunchie View Post
    I thought A3/S3 use same MC, so you shouldn't have to change MC for S3 set up
    Jan 2012
    464
    I thought you had to use VCDS to cycle the ABS pump to bleed these cars?
    May 2012
    Carlisle
    296
    Just a quick update. No master cylinder need. Just wernt bled up properly, needed to turn caliper upside down and then bleed then. All sorted don't notice a pedal problem at all.
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by Jambo26 View Post
    So you have the calipers on upside down?? The bleed nipple should always be on the top so no need to turn upside down.
    This way round.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    May 2012
    Carlisle
    296
    Can you take another pic of the caliper slightly higher up to see the pipe connections, as my pipes won't reach
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Are these pics any use?
    I'm working offshore at the moment lol.
    Audi S3 8P Brake pad replacement how to... | m.VAGOC.co.uk
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Found this on-line too.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    May 2012
    Carlisle
    296
    Thanks guys I will order the required parts on Monday.
    jsosic's Avatar
    Mar 2011
    Zagreb, Croatia, Croatia
    172
    Can you drive on 17" after upgrade or only on 18" wheels?
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by jsosic View Post
    Some 17's fit as these brakes also came on the V6 sport.
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    These are, in my opinion, the nicest OE wheels that will fit over the S3 sized brakes.
    My new car (photo's)
    Now:
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    jsosic's Avatar
    Mar 2011
    172
    What do you mean - "some". All of the OEM should fit, if one kind fits :D Looking at the pictures and judging by the caliper-to-rim distance majority of 17" should fit... If I ever encounter such a possibility I will aim at upgrade
    Yeah I've got those on my winter setup, but don't like them too much on white car...
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    Quote Originally Posted by martinivw View Post
    Correct, you only need to change if you step up to TT-RS/RS3/RS4 setup
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    550
    Would you need to change MC for brembo 4 pots?
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by Turbo jay View Post
    Depends on piston size, pm DaveB1970 he can tell you & supply you EXACTLY what you need based on your budget,
    R8 rear brakes(which are brembo 4 pots) I believe are supposed to give SUPERB results without changing MC,
    Of course that is only 1 of LOADS of options Just like everything else,it all depends how much you want to spend
    Turbo jay's Avatar
    Jul 2012
    North west
    550
    Thanks for the info
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    PM me if you need help. I'm an agent for vagbremtechnic (Daves company)
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Youd be better to do it through N8 as you will wait a WHILE to hear back from Dave
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    He's a busy man!
    Oct 2011
    7
    Jambo, any comment on braking performance with the S3 kit now fitted?
    Interested to hear whether it lives up to your expectations.
  28. #27
    May 2012
    Carlisle
    296
    I can defiantly feel a difference. But haven't had a chance to test them properly. I also need to to do the rears as well at some point .
  1. Whays needed to fit RS4 Brakes to an 1996 A6
    By K7ERG in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2007, 10:38
  2. How do I fit these? ... brake caliper caps???
    By monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2006, 09:29
  3. Anyone fitted R32 brakes to an S3
    By imported_Sem in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2005, 12:41
  4. Brembo's are fitted - Big Brakes Rock!
    By Ade_D in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2005, 23:25
  5. Kwik-Fit for brakes?
    By imported_mc119856 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2005, 11:51
