AH FabricationsVolks Autos
Results 1 to 18 of 18
Thread: Haldex Humming
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    Haldex Humming
    Hi!
    On my phone, so to cut a long story short, I have an A3 Quattro 2006 8P2 TDI 2L
    When I accelerate harshly, I get a loud humm (constant).
    When I reach 75mph & in 6th gear, I get a humming vibration, it resonates on and off continuously. Go above 80Mph and it goes away...
    I read I could disable Haldex by putting the hand brake on 1 click, I did this and went for a drive:
    No vibrations when accelerating.
    Only an extremely mild version of the above at 75mph in 6th. Hardly noticeable.
    I then took the handbrake off and BOOM! Vibrations.
    Haldex is shot? Oil change? Filter change? Pre charge pump? Per credit card max out pump? sell the car change?
    No errors on VCDS at all.
    Googled the hell out of this one to get this far! Hope someone can help with the above info.
    Thank you!
    Located in Newquay, Cornwall - Genuine VCDS Available for scans and mods
    Dipping and wrapping available, for your grilles and interior trims.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Disable the Haldex with the handbrake on one click????
    What your mileage? Has the oil ever been changed?
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    Yup, one click enough to put the parking light on in the dash. I was going to remove the fuse, but someone said it cost them £3k to fix, so decided against that one!
    Mileage is 87k - not been changed as far as I know, no. Would that cause this noise & would changing the oil fix it or has the damage been done?
    Audi Heaven
    Somerset
    1,861
    I can assure you this doesn't disable the Haldex unit, but you need to get your oil and filter changed as it should of been done twice at that mileage! Every 40k miles.
    There are recent threads on this very subject.
    Scott
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    Ok, but how come when the light in the dash goes off, it starts to vibrate immediately?
    Seems more than coinsidence.
    I will be getting the oil & filter changed ASAP. I saw the other thread but this humming is why I opened my own.
    Would the oil/filter change help you think or is it borked forever now?
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Quote Originally Posted by audicruiser View Post
    On the 8L's, the handbrake up used to disable the haldex
    Audi Heaven
    Somerset
    1,861
    Because the rear discs are clamping the axle and stopping the vibrations when you pull the handbrake.
    Get the oil changed and see what happens. You may of got to it in time...
    Scott
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    I already thought of that I again pulled on the handbrake up to see if it was the disks stopping the humming, but it didn't - I pulled it fairly hard too (bear in mind I was doing 75MPH).
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    I will change it, but is there anything else that would cause this? Could the rear drive shafts be mashed / bent or something?
    May 2012
    perth scotland
    424
    Quote Originally Posted by rokape View Post
    am i tired or am i reading this wrong? U PULLED THE HANDBRAKE HARD AT 75MPH!!!!
    Audi a3 3.2 v6 sport back ,s-line, Dolphin Grey with factory tints, deg sat nav, bose speakers, 18 upgraded alloys, magnaflow exhaust, eibach pro kit springs
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    Quote Originally Posted by discostu49 View Post
    Not quite as it sounded. I applied enough pressure to stop the humming if that were preventing it before, I didn't yank it on or even hard enough to change the speed of the car.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Haldex Humming
    Check your wheel bearings on the rear.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    Quote Originally Posted by shariain View Post
    Will get them checked tomorrow
    Jul 2012
    Cheshire/N Staffs
    1,379
    Handbrake on signal does de-couple the Haldex (on my Gen 4 unit) and 8P3's.
    So does the brake pedal switch.
    And the ESP on signal.
    All these signals de-couple the Haldex on the Gen 4 unit. Not sure about Gen 2 or 3.
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    Mar 2011
    67
    I have this same fault, and am about to pull my hair out over it.
    My advice is to be very careful before you start shelling out money on " fixing the fault"
    So far, I have been told it was the tires, then a buckled wheel, bent drive shaft, wheel bearing.
    All have been replaced and the fault still persists.
    The next thing I'm about to try is a replacement diff. I've brought it, just need to fit it. Will let you no how I get on.
    The only thing past that all this could be the rear prop/haldex coupling join. Have read a lot on this forum suggesting this is the fault, but the garage are adamant mine is fine?
    I will try and find the links.....
    Smithymartyn's Avatar
    Aug 2011
    34
    I had a similar fault, so feel yer Haldex 'pain.'
    When accelerating in a higher gear, I had a loud 'booming' noise coming from the rear diff. In the end, I had to have the Haldex coupling bearing replaced, a kind of donut in shape.
    Went to the steelers as had only recently purchased the car from an independent and warranty expired. From memory it was a £400+ job, but no doubt cheaper at a decent independent.
    Good luck, hope you sort it mate
    Apr 2012
    Tyne & Wear
    103
    Have a read of this, only really need to read once you get to Mr V pretty close to the bottom.
    I need to get mine sorted but just waiting till the MOT is out the way first.
    Audi 55reg quattro load vibrating at 2 thousands revs
    Mar 2011
    67
    Quote Originally Posted by Dean.no4 View Post
    Yeah, that's one of the threads I read before.
    I took my car to a well known Audi specialist asking them to change this part, they basically said no they won't, as they are so confident there is nothing wrong with the one on my car.
    As said before, they think my diff is at fault. I will change that soon and report back.
  1. Haldex pre-charge pump humming - normal?
    By Endacy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2011, 19:27
  2. Haldex oil change
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 09:32
  3. Question about haldex service
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 22:22
  4. Haldex Oil Change
    By ZAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 14:50
  5. MOVED: Haldex and Torsen
    By Mutley in forum Detailing
    Last Post: 7th July 2003, 15:01
