Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By NHN
Thread: Retrofit 2010 A3 Sportback Rear LED Light problem
    210_MIH's Avatar
    Drive it like u stole it
    May 2012
    103
    HI
    Just wondering if anyone has experienced this...
    When I put my headlights on, the rear LED ring lights up. Itsfine until I press the brake, and then the error warning comes on the dashsayin ‘right rear light’ and the outer off side rear light ring turns off - theone on the boot lid seems fine.
    I used these adaptors - (Audi A3 S3 8P or 8PA Sportback Facelift LED rear lights adapter cable set | eBay)
    and the lights were coded also...
    Im thinking maybe some water is getting in? As it happenedsoon after I washed it over the weekend... anyone had this issue or know aremedy? I read in another thread to usemultispray?
    Help appreciated.
    Mar 2011
    52
    sent u a reply mate
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by 210_MIH View Post
    HI
    Help appreciated.
    Ive had this problem also , adapters are terrible for catching and holding water, which caused it on mine, really need a certain member to hardwire them in when he comes up to bonnie Scotland ,
    Remove light and disconnect clean both adapters and try to position adapter in a different position
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,337
    Martin, we will need to get Nigel up here, maybe if we speak real nice to him he will come for a visit, he will love us all so much, he will just stay. Hope your reading this Nige? x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by Sandra View Post
    Absolutely , I'm sure he'll love the West Side, all joking aside I do know what he means about needing enough work to warrant his trip
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,337
    ​Thinking i may need to go a little jaunt to Italy and kidnap him, lmao. x
    26,758
    lol, thanks ladies, maybe if me & relations continue as going it maybe a move to the shetlands lmao.
    As per stated, never use adapters for various reasons, 1 being the water issue & it adds another link in the chain that can cause problems, plus wiring to the number plate bulbs is not by design, adds more load to a circuit not designed for, regardless what people think, prefer to do as oem as possible to avoid issues, which to date not had 1 come back for anything, without blowing my own trumpet
    Check to see if the adapters have the rubber seals to stop water getting in, if not then blame kufatec & they should know better as the original prefacelift connectors will have the seals for sure from factory.
    I also wrap them in tape from inside the car upto the connector for this very reason.
    martinivw likes this.
    210_MIH's Avatar
    May 2012
    103
    Thanks for all the help. the adapters were soaked in water. have wrapped them in PTFE tape followed by insulation tape. then zip tied them securely. hopefully no re-occurence.
  1. Sportback Rear LED Light Issues?
    By MONKIEE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2012, 07:54
  2. Problem with rear led lights
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd May 2012, 21:30
  3. Sportback Rear LED's
    By stealth64 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2012, 21:25
  4. Replies: 0
    Last Post: 19th September 2011, 17:41
  5. New Style Rear LED Lights/ sidelight bulb replacing
    By gazzaw888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2010, 22:14
