EM TuningAH Fabrications
    Nov 2005
    UK
    586
    Xenon headlights dipped beam adjustment
    Mornin' all,
    I drove the S3 in the dark for the first time last night since it had the Eibach front lowering springs fitted, and the dipped beam is definately set too low now, and lower than it was before the spring change which would make sense I guess.
    I thought the Auto-Levelling would recalibrate itself to account for the drop, but I presume after last night that it can only adjust within certain parameters which are set either using VCDS or using the manual adjustment on the headlight units themselves.
    Can someone please confirm what needs to be done to adjust them, and if I can do it myself or it needs a trip to the Stealers ?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Requires the use of VCDS to set the level.
    Basic Setting
    Headlight Adjustment
    [Select]
    [55 - Xenon Range]
    [Basic Settings - 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
    Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target. (On flat, set light 1%. Easiest way is drive right up to a wall. Mark a datum point for the centre of beam, drive back say 5m, now adjust beam so centre is 5cm below the datum.)
    [ON/OFF/Next]
    The adjustment should now be learned.
    [Done, Go Back]
    Don't forget to check/clear fault codes afterwards.
    [Close Controller, Go Back - 06]
    Nov 2005
    UK
    586
    Perfect....thanks for this.
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Would this same procedure work on a 2010 TT?
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    yeah it will be the same modules are the same
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
  1. Headlight beam adjuster broken
    By gavsman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2012, 08:39
  2. Headlight beam adjustment for european driving
    By crazylegscrane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2009, 00:13
  3. Headlight beam pattern and Xenons
    By cyberdude in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th May 2004, 19:09
  4. Headlight height adjustment
    By Gaunty in forum Volkswagen and other VAG
    Last Post: 22nd December 2003, 16:53
