Monster MotorsportChris Nott
    Jul 2012
    7
    Urgent help needed, Audi a3 2.0 tdi sline 2004
    hi,does anyone know how to check the injectors if they are working & done a full service and changed all the glow plugs but the car take longer to start when warmed up any idea why.
    Gazzago's Avatar
    May 2012
    61
    Sorry mate I can't help much. I have the same car and it takes longer to start when warm than cold.
    Had one glow plug out when I got it, changed it and made no difference.
    Reading around it could be the timing needs fine tuning. Going to try this when I get my vcds at the end of the month.
    Interested in any other ideas of what it could be.
    Gary
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,001,884
    Follow Administrators On Twitter
    It could be the starter motor.... I'm not trying to be funny. Am I right in thinking that the car cranks over for a long time before it starts in a cloud of smoke? It will start better some times for no real reason.
    If this is the case it maybe your started motor isn't turning the engine quick enough/produce enough torque for the ECU to allow car to start. One way to see is to disconnect the water temp sensor and try and start it. You might find that the car starts on the button.
    If this is the case you might find a new starter will help. You might also want to check the temp sensor is reading ok as well.
    Best of luck
    A
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,618
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
  1. Urgent help needed, Audi a3 2.0 tdi sline 2004
    By cheeco in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st July 2012, 12:35
  2. Urgent Help needed with Audi 2.0FSI..
    By l33tgama in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2011, 00:42
  3. urgent help needed with my 2007 audi s3 please!!!
    By s3r4pid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2010, 18:30
  4. urgent help needed with my 2007 audi s3 please!!!
    Last Post: 14th December 2010, 10:09
  5. Urgent Help needed - How to replace air con pump on 2.0 tdi
    By m.lemon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 22:57
