Hello Chaps,
Hoping that some of you might be able to shed some more light on the problems I have.
I have a 2.0FSI N/A A3 on 04 plate, recently the car started behaving erraticaly. When I try and start it turns over a few times before it kicks in. Tested the battery and it's spot on. Today when I set off for work I was in 2nd gear and the car suddenly lost it's power for a split second. It felt like someone slammed on the brakes and then came back to normal. The engine sounds like a ****** diesel.
I have one of those cheap handhel scanners from ebay so I plugged it in to see what comes up and we have the following codes :
16395/P0011/000017 - Bank 1: Camshaft A (Intake): ****** Setpoint not Reached (Over-Advanced) [h=4]Possible Symptoms[/h]
16725/P0341/000833 - Camshaft Position Sensor (G40): Implausible Signal
And last but not least we have this :
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow [h=4]Possible Symptoms[/h]
If anyone can help and shed some light that would be really appreciated.
Jack
- Power Loss
- Camshaft Adjustment Valve 1 (N205) faulty
- Fuel Pump Relay (J17) faulty
- Mechanical Timing not correct, including Chain and/or Belt timing.
- Check Camshaft Adjustment Valve 1 (N205)
- Check Fuel Pump Relay (J17)
- Check Mechanical Timing
- When found in Engine: 4.0l W8
- Check TPL 2010059(RoW)
- Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
- Malfunction Indicator Light (MIL) active
- Wiring from/to Camshaft Position Sensor (G40) faulty
- Camshaft Position Sensor (G40) faulty
- Timing misaligned
- Check Wiring from/to Camshaft Position Sensor (G40)
- Check Camshaft Position Sensor (G40)
- Check Timing
- Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
- Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
- Evaporative Emission (EVAP) Canister Sealing faulty
- Pipes between Tank Breathing and Throttle Body leaky/blocked
- Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
- Perform Output Test
- Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
- Perform Basic Setting
- Check Pipes between Tank Breathing and Throttle Body
- When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB
- When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB
- Note: The Passat 26E5 or "R5" recall includes the same software update
- Make sure the quick release lines for the N80 valve and vacuum line to LDP are not crossed.
- This can also make the engine hard to start after filling up the fuel tank.
Jack
