Monster MotorsportChris Nott
    Aug 2012
    Battery problems A3 TDi170
    Hi guys,
    I've got an A3 TDi170 which has been suffering from flat batteries.
    On Saturday started it in the morning and it started fine. Drove it to several places all fine. Went to supermarket, was in supermarket for 10 minutes, came out and car wouldn't start. RAC man said it was battery, tested the battery and it was flat. He jumped it and it started perfectly. He tested the alternator and the drain on the battery (when engine off) and both were within normal levels. He couldn't really advise me what to do, he said specifically that the battery was healthy and it would be a waste to buy a new one.
    Yesterday same thing happened. Drove it fine in the morning to work. Drove it to the in-laws. Got out of car, picked up kids, got in car and wouldn't start. I jumped it myself this time off the in-laws van and again a healthy start.
    What do I do? If there is no drain, the battery is healthy and the alternator is charging correctly i'm stumped.
    The side repeater is broken. Could this potentially cause a problem? i/e water getting in etc? I'm sceptical because it wasn't raining on either day but it's the only thing i can think.
    Any help would be greatly appreciated!!
    Sportback owner
    Apr 2007
    France
    486
    Steve a fully charged good battery does not go flat so easily. Some ideas. 1) Trickle charge the battery overnight until the charger indicates a full charge. If it goes flat quickly then 2) this battery has an internal short, high internal resistance, or some chemical problems which prevent it holding a charge. It is possible that you have somehow discharged the battery, and now the car is not running sufficiently to charge the battery to a reasonable level. Remember, a diesel takes a hugh whack of current when starting. 3) borrow another battery for a few days and see what happens. 4) not sure how the RAC man could say that the battery was 'healthy' unless he had made a proper high discharge test when the battery was fully charged. 5) if indeed the RAC man has determined that the current drain when engine off was within normal limits (small) then the side repeater would not be a problem. My guess is a bad battery.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    This is the only real problem I had with my car within the 3 year warranty period. It went it to Audi 3/4 times and each time they did a drain test and it would come back with no faults, even though I would state to have a new battery they said because it wasn't showing as faulty there was nothing that they could do!
    I would go 3-4 weeks with it being okay and then dying. The last time it went in, they did a drain test and finally appeared faulty, so replaced it and was fine. But I recommend upgrading to a Varta Silver Dynamic, great batteries, perfect if you have lots of tech in the car for sure
    coxy8329's Avatar
    Nov 2011
    Hampshire
    166
    I had a battery charging problem on my Seat Ibiza TDi basically the alternator would not start working until the engine had been over 2000 rpm after which it would charge through the entire rev range with no issues.
    Probably not the same but thought I'd share.
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
  1. Battery problem getting worse and worse
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th December 2009, 21:48
  2. Battery Problems!!! Please help
    By Steve_D in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2009, 09:52
  3. Battery problems
    By Crazypete00 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2008, 11:07
  4. Battery Problem
    By mnadeem1984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2006, 18:11
  5. Battery Problems (Audi S3)
    By Vman in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2005, 10:04
