Monster MotorsportEM Tuning
Results 1 to 12 of 12
    BigWillyStyle's Avatar
    Aug 2012
    566
    A problem starting when engine temp is at half way......
    Hi, as above really.
    I Was hoping someone hcould help me solve this problem. Car starts fine when the engine is cold normally, sometimes stalls but not often.After a journey and and the engine temp is at about half away and i try to start the engine again it misfires then starts.
    Its been on a Diagnostic machine and no fault codes.
    The model is an 04 A3 S-line btw.
    Thanks in advance, Will
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    2.0 TDI?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Aug 2012
    566
    Ah yes sorry, a 2.0 TDI....
    warren_S5's Avatar
    Oct 2007
    7,133
    Any lights on the dashboard???
    I'm sure I've read somewhere TDi's can suffer with coked up throttle bodies. Usually a starting issue will be driven by air / fuel mixing or lack of strong ignition, so it's the natural starting point for any investigation. Check there are no pipe leaks etc.
    Cheapest test might be to put some TDi specific injector cleaner through the car and see if it has any effect. When was it last serviced?
    My bro-in laws 170TDi has just had injectors replaced and the injector loom (by Audi even though out of warranty), but I'm not sure if this issue is the same on the 140's.
    Audi S5 3.0V6T Coupe Black Edition
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    Aug 2012
    566
    warren_S3- The only light that has popped up a couple of times is the passenger air bag. Its been knocked off but comes back on. I'll have to look when it was last serviced as ive just bought the car but the air filter does need changing. Ive already changed the fuel filter. Just hoping its nothing too serious. Thanks for the reply.
    mjr901- Thanks i'll read that when the Boss is not looking over my shoulder
    Fossie
    Rhubarb Triangle
    3,969
    Starter motor is a common cause of this problem
    Aug 2012
    566
    Hi, little bit of an update.....Today when i started the car and left it in park i noticed that the engine had a little bit of a rattling noise coming from the main part of it. The rattle wasnt constant but more of an intermitent rattle but do you think this could be anything more sinister? Thanks in advance....
    Aug 2012
    566
    Anybody?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by BigWillyStyle View Post
    Sorry mate but ' a little bit of a rattling noise' isn't going to get any replies !
    You would need to be more specific about the rattle, perhaps even to the extent of a video with audio. The rattle is not necessarily symptomatic with the starting problems.
    Aug 2012
    566
    I'm hopeless at posting vids etc....
    I've only just noticed the noise but dont think it rattles when the engine is hot. I'll have a listen later on and hopefully get more info.
    Feb 2012
    Chelmsford Essex
    22
    the rattle sounds like the duel mass flywheel to me , mine needs one !
  1. A6 2000 2.7t - won't start when engine semi warm
    By dan small in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd October 2013, 09:57
  2. S4 problems starting when warm
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2010, 14:52
  3. ECU Engine temp sensor - difficult start when warm
    By James09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 19:52
  4. Engine Temp Dial - AND Air Con Problem
    By A13X-A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2007, 20:38
  5. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
