JMB RetrofitsAH Fabrications
    Jul 2012
    17
    BRAKE DISCS WARPNG TOO QUICK
    hi
    i have an audi a3 3.2 s line and the drivers side brake disc warps way too quickly, a mechanic checked it and said it could be the caliper carrier so i had this changed along with the discs costing me in total around £500, however a month or 2 later same problem now i have been told it could be the caliper itself can any1 plz shed some light as i cant afford to change things that dont need changing.
    thanks
    Apr 2012
    N. Wales, LL22
    1,224
    check with a thermometer
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    500 for a carrier discs ?
    robbing ****
    jamessg1962's Avatar
    Jan 2006
    Newcastle
    116
    Hi
    Have you checked that the piston is retracting after applying the brakes ? If thecalliperr piston is sticking causing the pads to continuouslyy rub the disc's this will cause disc warp.
    Jack up that side try spinnig wheel after aplying brakes a few times, it should turd freely. Also have you noticed any premature pad wear compared to other side.
    Have you got the correct pads and disc's . Some non O.E.M disc's might not be up to the job. are they vented disc's ?
    Have you replaced the pads with a hard type ?
    Hope you get it sorted mate as you don't want to be spending that kind of dough often.
  1. Brembo max brake discs???
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2005, 19:32
  2. For Sale - 1 x Neon Brake Disc...
    By FactionOne in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2004, 18:02
  3. Passat W8 Brake discs
    By james_dj in forum Volkswagen and other VAG
    Last Post: 29th July 2004, 23:45
  4. Brake Discs
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2003, 18:26
