JMB RetrofitsSky Insurance
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Unhappy The ERROR CODES on my car after I vag commed it: Need help :AGAIN: :)
    What are those, what to do in order to fix them ? ( spare parts to replace or what to do )
    * Engine Electricty ( P1912 )
    G294 Error Code - Some pressure sensor for the brakes I guess ?
    Short circuit to chasis
    * Engine electronics (P1479)
    Brake low pressure system - V192 Brake servo pump
    * Electroniccentral electric (02195) Button & cluster illumination controller -E20 - disjointed/ short circuit against to chasis
    J519 - Cental electric controller unit, cluster illumination, terminal 58d
    * Airbag - (00588) - N95
    Airbag launcher - driver side
    Could you please advice?
    thanks a lot
    '' Wanna Trade Your Pre-facelift BRUSHED ALU interior trim with my Piano Black ones? '' PM me..
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    You should find what you need here.... Ross-Tech Wiki
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  1. HELP!!! error codes, cars shaking whens the engine is on.
    By namskis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2012, 16:22
  2. What is the paint code for Imola Yellow? (my car)
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2012, 22:23
  3. Worry! The error that CR800 Code Reader didn't check out
    By daviscandy in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2012, 10:57
  4. What the best Wax for your Car
    By S3_quattro in forum Detailing
    Last Post: 9th April 2004, 13:29
  5. MOVED: What the best Wax for your Car
    By S3_quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2003, 10:57
