Monster MotorsportEM Tuning
    Jul 2012
    Leicester, UK
    73
    Wynn's Diesel Particulate Filter Cleaner
    Halfords | Wynn's Diesel Particulate Filter Cleaner 325ml
    Does the above product work or is it just a gimmick ?
    has anybody used it and seen and difference/improvements ?
    any additives that are good for the car ?
    Audi A3 2.0 TDi Sportback ¦ Phantom Pearl Black ¦ 16" alloys ¦ 58 Plate ¦ Acoustic Rear Parking System ¦ Criuse Control ¦ Interior Light Package ¦ Light & Rain Sensor ¦ Door Mirrors Auto Dimming and Folding
    Jul 2012
    Leicester, UK
    73
    anuybody ? nobody ?
    warren_S5's Avatar
    Oct 2007
    7,166
    I've not heard it mentioned by anyone.
    Don't own a diesel myself, but bro in law does, and dealer has told him that due to short journeys they do only way to stop DPF issues is by running the car at high revs once in a while (it's an A3 170TDi). Unbelievable really that you can't just drive your car and it takes care of itself between services! Not aware he's been told to try any additives.
    dex140's Avatar
    Dec 2009
    190
    Maybe post this in the diesel section?
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by icekay View Post
    Its not required... The car cleans and regenerates the DPF itself and if the light does come up on the dash then a brisk 30 mins dual carriageway drive will sort it.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Sep 2012
    Hi, I had problems with the DPF and used this: Halfords | Wynn's Diesel Particulate Filter Cleaner 325ml
    It made a difference. You can't go wrong for £10
    I still have a problem, hope that someone can help me here:
    A few months ago I started getting the MIL light on the screen and in the middle screen error saying "Particle filter problem".
    I have ignored it for a while and took it on the motorway. Error displaying randomly.
    What I have noticed is that when I was getting the Particle filter message in the middle screen The engine was getting hot and the Radiator fan was blowing v hard. Also losing power / coil light on
    Ignored it got and the coil light disappeared.
    After 2 months of driving with MIL on I used the VAG tool and read these codes:
    5253 - Diesel Particle Filter; Differential Pressure Sensor: Elect. Malfunction
    P2452 00 [175] - No or Incorrect Basic Setting / Adaptation
    Freeze Frame
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Date: 2000.00.00
    Time: 00:00:00
    5262 - Diesel Particle Filter; Differential Pressure Sensor: Short to GND
    P2454 00 [032] - Defective
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 111264 km
    Date: 2000.00.00
    Time: 00:00:00
    Cleared codes but came back immediately.
    I have checked the fuses in the boot (right side) using a multimeter (without taking the fuses out) and found one fuse blown. 15A - blue in the Orange/Red fuse carrier. (According to the manual it's "Socket, centre console, rear").
    Replaced the fuse, now getting ONE error:
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 2
    Date: 2000.00.00
    Time: 00:00:00
    After clearing the error it comes back immediately. MIL showing up after a few miles.
    Followed: 18884/P2452/009298 - Ross-Tech Wiki
    And tried to “Check Measuring Values” but cannot do Meas. Block – 08 as it’s greyed out. Used Advanced Measuring Values and have the following results while in idle:
    Particle filter, difference pressure Loc.152 0 hPa – is this normal or the sensor is faulty?
    Particle filter, oil ash volume Loc.164 0.08l
    Particle filter, offset for differential press. Loc.165 47 hPa
    Particle filter, time since last regeneration Loc.168 15201 s
    Particle filter, field regeneration lock status Loc.153 00000000
    Particle filter, field regeneration lock status Loc.161 0
    Particle filter, kilometres since last regeneration Loc.162 118941 m
    Particle filter, fuel consumption since last regeneration Loc.163 9.59l
    Reading other people’s posts I should try:
    1. Replace the differential pressure transmitter:
    0281002760
    35/08 1 E F 4 816
    07Z 906 051 B
    Any ideas where I can get it from?
    2. Or do a regeneration, if so should I follow instructions from here: Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
    If so which one? Idle or run?
    Can someone please advise if this is correct? Or do you have any idea what I should be doing?
    I have attached 2 pictures.
    I have an A4 B8 2.0l TDI 6-speed manual 58 plate SE - AMI – Chassis 8K, Engine (J623-CAGA)
    Many thanks and best wishes.
    Andrei.
  1. Diesel particulate filter
    By Chris71 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2011, 19:25
  2. Replies: 5
    Last Post: 16th March 2011, 15:07
  3. How to clear a blocked diesel particulate filter
    By Matty1234 in forum Diesel forum
    Last Post: 30th May 2010, 09:54
  4. Redex Diesel Fuel System Cleaner
    By SimonP in forum Diesel forum
    Last Post: 24th July 2007, 21:23
  5. particulate filter on 02 A4 TDi
    By nlldavies in forum Diesel forum
    Last Post: 16th January 2007, 19:16
