Chris NottAH Fabrications
Results 1 to 15 of 15
    Jun 2010
    9
    Lightbulb Audi A3 8P Mk2 2010 Xenon Headlight Upgrade Assistance Please
    Hi Everyone
    Am in process of upgrading the A3 with Xenon Headlight
    The Car is a 2010 Facelift A3 2.0 TDI Right hand drive which currently has halogen lights
    The Bi Xenon headlights I have acquired are the following:
    Nearside Headlight 8P0 941 003 1ZS 009 648-17
    Driver side Headlight 8P0 941 004 1EL 009 648-10
    Pictures:
    The Current headlights fitted to the car are the following part numbers:
    Nearside Headlight 8P0 941 003 1LJ 009 648-03
    Driver side Headlight 8P0 941 004 1LJ 009 648-04
    See Pictures:
    The car currently has the following CECM (Central Electronics Board) in place 8P0 907 279N
    In my understanding this CECM will support the headlight Upgrade
    The instrument cluster installed in the car is the following part number: 8P0 920 982 C
    I do not wish to install the headlight levelling or washers as yet. For now i just want to get the headlights to work without any errors displayed on the dash
    Can some one please point me to the a link or a supplier who can send me the correct adapters for the upgrade
    And also advise me on the best way of getting these 2 wires threw the bulk head that go to the CECM and where in the board these 2 wires go.
    According to my research this is all i need to do to get them working correctly without any errors,
    Have i missed anything?
    Many Thanks
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    Hi Mate,
    the adapters you need are these ones: KUFATEC GmbH & Co. KG - Xenon/HID Headlights - Adapter- Audi A3 8P & 8PA Facelift
    select the 2009 ones since you have the N rev CE module.
    the wires go through under the drivers side scuttle panel and under a panel there into the drivers footwell.
    Once installed you will need to code the CE module for it to work properly without errors.
    Where abouts are you? I can do this install for you if you need?
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    27,093
    Ok your biggest problem "which someone should of advised 1st" is, both headlights are left hand drive so useless on UK roads for mot's, it will fail on the beam alone, also 1 headlight is normal bixenon & other is adaptive, so if you ever come to do the levelling system, you're basically goosed as it wont work.
    If you want to sort out the proper headlights for UK roads then give me a shout as I can get brand new for you delivered.
    Jun 2010
    9
    Hi which xenon is non adaptive and which one is adaptive?
    Which part of the part number tells you this
    And how do u know if they are for left hand drive?
    And what sort of money am i looking at for the correct ones?
    Many thanks
    27,093
    003 changes to 029 & 004 changes to 030, but the important part are the letters on end, AR is adaptive & these denote to us sided versions aswell.
    PM me for prices.
    Jun 2010
    9
    PM sent
    Jun 2010
    9
    If I was to fit these headlights will I be able to get then working correctly bearing in mind one of them Is adaptive?
    By working correctly I mean no warning lights and lights comin on as they should?
    Do I new to have the adaptive module for the other headlight to get the lights to work with put any issues?
    Many thanks
    Nov 2012
    hi pal i have got an problem wiv mine,, mines like this chaps wiv the halogen headlights but the problem is i know you connect the pins in the ce module but which slots but and also the drls are to dimm
    Nov 2012
    alos forgot to mention mines the 2008 facelift model which adapters do i need if it is the adapters
    Dec 2013
    Hi, im looking at old posts and I am battling to understand the the headlamp labelling. How do you know by looking at the label if its LHD OR RHD and Xenon or Bi-xenon and if its adaptive or not?
    Could you explain?
    27,093
    Part numbers & the actual parts catalogue differentiates them with these numbers.
    Apr 2013
    London
    135
    Quote Originally Posted by harrys View Post
    Could you explain?
    I was confused recently too mate. Correct me if im wrong but i think all facelift headlights are either halogen or bi-xenon. I dont think you can get normal xenons?
    Jul 2013
    7
    I no this is a old thread but can anyone tell me where the too extra wires go to on the cecm it self (what pins)
    Thanks in advance.
    Lewbo's Avatar
    Aug 2009
    Hull
    1,047
    What year car do you have mate?
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Jul 2013
    7
    Its a 2011 (61) plate sportback.
  1. Audi a3 S3 black edition xenon headlight adjusting
    By 210_MIH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th April 2013, 20:10
  2. Audi a3 sline bumper and xenon headlight wanted
    By H88 in forum For Sale/Wanted - Audi Cars
    Last Post: 28th June 2012, 18:18
  3. HID/Xenon Headlight help needed please
    By Diesel Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2011, 18:46
  4. Audi A3 8L Sound-System (Non Bose) Upgrade Advice Please...
    By Lingo89 in forum In-Car Entertainment
    Last Post: 12th July 2011, 19:46
  5. A3 xenon headlight upgrade
    By M88JCP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2010, 10:19
