    Jul 2012
    7
    urgent Audi a3 2.0 tdi sline how to adjust the idle manually or with vcds.
    how can i adjust the idle manually or with vcds.
    Fossie
    Rhubarb Triangle
    3,969
    You can't do it manually. I posted a thread giving details on how to do it using VCDS some 18 months ago but can't remember what to do. I'll see if I can find it.
    Edit: here it is :- https://www.audi-sport.net/vb/vcds-f...k-over-up.html
    Edit 2 :- ignore the comment about version 908 - it works ok with 11.11.3 (latest) as well
    Jul 2012
    7
    ok thanks will be great help.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by cheeco View Post
    Check my first post - I have edited it with the thread details
  1. Audi A4 1.9 TDI - Roughly how much is it worth?
    By amz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2013, 13:33
  2. Urgent help needed, Audi a3 2.0 tdi sline 2004
    By cheeco in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st July 2012, 12:35
  3. Audi a3 2.0 tdi sline
    Last Post: 29th July 2012, 19:08
  4. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  5. 2001 - 2004 A4 TDI's - How to tell the difference - Help Required
    By AliasOmega in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2008, 16:56
