AH FabricationsSky Insurance
Results 1 to 16 of 16
Thread: Wiper Position
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,159
    Wiper Position
    Since I've had my 2009 Sportback (bought used), the drivers wiper leaves a huge annoying un-swept area near the A pillar which affects vision out in wet weather. (ref pic which I've drawn a black line so it's easier to see the issue).
    When parked, they sit nicely under the bonnet line. Blades are the correct length and original to car.
    I do not remember this being an issue with my previous 2004 8P A3 3door
    Is there anyway to adjust this?
    Fossie
    Rhubarb Triangle
    3,961
    Not adjustable - that is the full throw of the wipers !
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    my wiper goes all the way to the edge of the window. you can open the bonnet and loosen the nut on the wiper and then move the wiper up a little so that the throw will go more to the edge.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Ash187 View Post
    Surely if you adjust the position by moving the knurled cap a notch up then the top of the blade, when on full sweep, will throw past the windscreen onto the 'A' pillar ? The only way for the wiper to catch the whole area is for it to have a swivel mechanism so that on full sweep the top end of the blade stops at the edge of the glass and the bottom end swivels further outwards to complete the wider sweep at the base of the screen !!
    Nice idea if someone could come up with a 'swivelling blade' !!!lol
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    no Mike, My wiper is wiping perfectly and covering the whole window without leaving a silly sweep mark in my line of view. by simply taking off the wiper arm and adjusting it slightly higher does not cause an issue. as you can see in the OPs pic the wiper sweep is still 2 inches from the edge
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    Fossie
    Rhubarb Triangle
    3,961
    I'm intrigued Ash ! I don't understand how lifting the arm by a notch will cause the bottom of the blade to do a full sweep UNLESS you lift it by a notch and then bend the arm slightly in a downwards direction to change the angle of attack ! That would effectively move the whole arm outwards towards the edge of the glass on full sweep!
    To be continued ( 'cos got to go out and would like to resolve ) !!
    antmax7's Avatar
    sheffield
    300
    The main issue for the original poster is the vision higher on the screen than the lower part of the blade is it not??
    As ash has said if you adjust the wiper arm by a notch or 2 then this Will resolve the issue
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,623
    I hope you're not going out to bend the wiper arm.
    my 09 SB wipes to within 2 inches of the A pillar. Ash is correct, remove the arm and rotate it a notch or 2 on the spindle to solve this.
    The parked O\S wiper should just be visible above the bonnet line.
    2009 A3 SB 2.0T DSG S line
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,613
    Quote Originally Posted by Artimus View Post
    Yup, dont go bending anything!!!!
    Its a 5 min job if that!!!! They adjust well easily!!! all wipers do!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,159
    Thanks for all the constructive replies. I think bending anything would be wrong.
    If the wiper are is moved a notch or two on the spindle, when in parked position will it still sit unseen under the bonnet line?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    for me as long as the wiper cannot be see while i am driving then i am happy. I currently have the wiper positioned to wipe to the edge of the glass but still when its parked i dont see it.
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,159
    Quick update............
    Thanks for the help guys.
    13mm sockect required to remove the arm.
    With a bit of precision adjustment (only the slightest movement needed), repositioned the wiper arm. Viewed from the outside, top of wiper now sweeps to about 15mm from the A pillar, which viewed from inside the car, practically leaves no unsweep area...perfect... Also in park position wiper still looks quite horizontal.
    Initially I thought the drive spindle had a spline drive like other cars. But on the A3 it's a simple taper (no notches) which results in infinite positioning of the arm on the spindle.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    glad to be of help mate!
    and Mike Foster you should try to trust in some advise given.
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    Fossie
    Rhubarb Triangle
    3,961
    No mistrust Ash - I was just trying to understand the mechanics of the thing. Been out to my car and stopped the wipers at the full sweep position and the drivers side is just about parallel with, and about an inch and a bit from the pillar so I don't have the problem for some reason.
    Sorry if you thought I was disputing your advice - I wasn't.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,623
    Now this has been resolved.
    Another thing of note is that ...on MY09 at least... the wiper park position changes with every use! It will sit up on the 1st single stroke, and down on the next. This is deliberate, it's designed to reduce the 'training' of the blade into a preferable back or forward sweep & so reduce judder.
    A neat trick & great attention to detail..
    Jun 2013
    22
    Found this thread useful when searching.
    Iv recently purchased my car and here's how the wipers park...
  1. Need some help. A3 wiper service position.
    By micasb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2011, 17:01
  2. Wipers - mucked up positioning!! Help!
    By stephanbegley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2010, 17:56
  3. Why do my wipers not stop in 'service position'?
    By Chappy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2010, 16:10
  4. Service position for wipers
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2008, 13:20
  5. Wiper resting position
    By exciter01 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2006, 15:33
