EM TuningSky Insurance
    Jan 2012
    106
    Boot Locking Problems
    I have problems with the boot lock, I'm not convinced its the soft touch mircoswitch so thought I'd ask on here first. To summarise my problem:
    1. If the car is locked and I double unlock on the keyfob and then push the soft touch mircoswitch to open boot it opens no problems.
    2. If the car is unlocked and I push the boot unlock button on the keyfob (the light on the keyfob flashes) I hear nothing and pushing the soft touch mircoswitch does nothing.
    3. So basically if I want to unlock the boot when the car is already unlocked sometimes a double unlock/soft touch mircoswitch works other times I need to lock then double unlock/soft touch mircoswitch and generally faff around like an idiot until it finally decides to work.
    To me it seems like some sort of control system issue since it always unlocks when the car has been locked for a period of time. Also I should add I've only had the car 6 months I found out after purchase the boot was busted.
    There is no water damage from window washer.
    Any ideas?
    Fossie
    Rhubarb Triangle
    3,969
    What is a 'soft-touch microswitch' ???
    Jan 2012
    106
    The bit you push with your fingers to open the boot, above the number plate. Seen someone call it that in another thread. Not sure what else to call it!
    Fossie
    Rhubarb Triangle
    3,969
    If the car is unlocked then don't press the remote, just use the 'soft touch'. If the car is locked then you have to press and hold the middle button to open.
    Jan 2012
    106
    Cheers got it now, the instruction manual says press the boot unlock button, not hold. Never had boot unlock on keyfob before.
  1. Avant boot lock problem
    By Paul @ Unit in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2011, 19:53
  2. Boot Lock Problem
    By highlanderorr in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2011, 20:08
  3. Boot lock problem, NOW WITH PIC
    By Mick a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2011, 17:16
  4. 2005 A4 saloon, boot locking problems
    By swfirestorm in forum General Chat
    Last Post: 3rd November 2010, 21:57
  5. Help with A4 boot lock problem
    By Steve_D in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2010, 13:23
