AH FabricationsSky Insurance
Results 1 to 10 of 10
    Jul 2012
    Leeds
    A3 Quattro Rear Disc Removal
    I'm trying to find out whether or not the calliper carriers need to be removed to be able to replace the rear discs on a Quattro. I've already had a go at taking them off without removing the carrier without any luck. I've loosened the disc and had it nearlly off, but the edges of the carrier are stopping it. Is there a special method to do this? Or am I wasting my time trying to find a way?
    Do the carriers need to come off it? If so I'll have to take it to a garage as I can't for the life of me release those bolts (I have the M14 spline bit and I've put a fair amount of penetrative oil and strength into it too).
    antmax7's Avatar
    sheffield
    300
    Have you tried turning it the other way just a thought they might be left hand thread???
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    Yes the carrier does need to come off. They are held on by 2 big splined bolts and you'll need a nice big bar on them - although there isn't much room in there to get the bar into.
    They are a standard thread and not left handed thread.
    I did the rear brakes on my old A3 Quattro and it was a bit of a ***** to do.
    Jul 2012
    Leeds
    Quote Originally Posted by RobinA3 View Post
    I was afraid of that. I'll give it a good go when I can next. Either that or send it to the local garage and let them swear at it.
    S3 Owner
    Feb 2009
    Aberdeen
    414
    Carriers normally have to come off for new discs.. If it was pads only you'd be fine
    Aug 2010
    Earth
    It's a pita to take the carrier off. I really advise you to pay for this. M14 bolts are torqued to 90NM (66lb-ft)+90 degrees and this is insane in terms of final torque. You wont be able to move them on jack stands. And yes, you must take the caliper carrier off.
    Feb 2012
    37
    HI
    I have just done the discs and pads all round on my 57 plate 2.0 170 sportback
    and managed to do the rears WITHOUT taking calipers off
    you just jiggle them and they will come off well mine did
    not sure if same rear brakes as yours thou
    fronts 312x25
    rears 255 x 10 i think thrown boxes away now
    cheers bing
    Jul 2012
    Leeds
    Right, Think I'm gonna give it one more try then I'm going to pay a monkey with a big wrench to do it for me if I fail.
    Oh, and the discs I have are 286mm
    Jul 2012
    Cheshire/N Staffs
    709
    Impact wrench?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    Quote Originally Posted by bing View Post
    HI
    fronts 312x25
    cheers bing
    Quattro's are different and the carrier does need to come off.
    It can be done on axle stands - i did them on axle stands, you just need a good selection of tools and some epic strength!
    You can get an impact good in there as space is soooooo limited!
    Its a right pain in the arse of a job.
  1. Audi A4 2.5 TDI Quattro Rear Discs
    By jameshughes1974 in forum For Sale/Wanted - Audi Parts
    Last Post: 26th May 2012, 10:25
  2. A6 Avant quattro rear discs question
    By Inskip75 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th January 2010, 05:52
  3. a3 quattro rear disc and pads?
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2007, 23:40
  4. S4 Rear Discs/Calipers onto A4 Quattro?
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2005, 16:59
  5. Rear Bumper Removal
    By Jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 13:10
