AH FabricationsChris Nott
Results 1 to 9 of 9
    Jul 2012
    Shropshire
    32
    Cold start problems A3 Diesel + Video
    Hi Everyone,
    Hope someone can help. I'm having some cold start problems with my 2005 A3 2.0l tdi BKD Auto (mileage 95k).
    If its left for more than a few hours it struggles to start, it feels like fuel starvation. It also hesitates badly at low speed. However once it's warm it drives perfectly - great mpg 60+, no issues. In the last 100 miles I've had the cambelt done and also the fuel filter. Only just taken ownership of the car so not sure if it was bad before the service.
    Had a look at the fuel hoses around the fuel filter and they all look ok (not split). It came up with some glow plug faults a few weeks ago: codes: 17055, 17056, 17057 & 17058. Should I replace all the glow plugs?
    Just filled up with a tank of V Power diesel and given it some Redex......
    Ill post a video of the problem in a few hours what does everyone think?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,159
    Yip at the mileage I'd change the glow plugs and possibly the relay to.
    Sportback owner
    Apr 2007
    France
    465
    If the engine is cranking strongly I would suspect that the glowplugs do need changing. You can measure the resitance of each glowplug. Search on this forum for advice on how to do this and what to expect as resistance readings. Also checkout or replace the glowplug wiring harness (perhaps combined with the injector harness). Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Aug 2011
    47
    i had a cold start problem on mine, that went away when warm,turned out the cambelt wasnt fitted correctly
    Jul 2012
    Shropshire
    32
    Quote Originally Posted by nokia_aid View Post
    Eh...was hoping this wasn't the case. I'll talk to the mechanic that did the cambelt after i've tested the ignition systems.
    H88
    H88's Avatar
    Apr 2012
    Lewisham/London
    232
    I had the similar and I just replace the glow plugs. It starts much quicker and better than before.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Lets clear a couple of things up here, the glow plugs are only used at engine start up & not after, & even then they only really do something when the temperature is very low, as the weather isn't freezing at the moment I'd go out on a limb & say they aren't the cause of your problems.
    The Injector loom & Glow plug loom are linked & it is a well know fault on the BKD (& BMN) that they can fail & give intermitent signals (hence the fault codes), it worth getting this checked.
    You say that the cambelt was recently done, did they also check the Torsion value after the belt was done? Ideally you need to be at 0 to 0.5 degrees or the engine can be an absolute pig to start & will idle really rough till the engine warms up.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Jul 2012
    Shropshire
    32
    Thanks for all the help everyone! I've just tested the battery on my multimeter and it's coming back with 12.49v so it appears to be fine.
    Its not exactly thrilling but the above link shows the problem - admittedly it started second time but it's usually the 4th or 5th time. You can hear the accelerator click on kick down as it requires a heavy right foot to get it to start, unless you kick down nothing happens.
    Please note It sounds especially tractor'ish as the window is down on a cold engine. It sounds alright when warm - honest!
    Jul 2012
    Shropshire
    32
    If anyone stumbles across this post with the same symptoms I can confirm that my timing belt was out - 2 teeth retarded. Horrible cold start, big cough of white smoke from exhaust and a terrible hesitation until warm.
    Garage suspect a small piece of the timing cover had broken off and slipped the belt. Who knows.....all fixed now though.
  1. 2004 a4 2.5 diesel cold start problems and white smoke
    By B16dev in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2012, 13:55
  2. A4 2.5tdi cold starting problem
    By Quattro john in forum Diesel forum
    Last Post: 26th July 2009, 13:09
  3. S3 Cold Start Problem
    By squale in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2008, 01:15
  4. Cold start problem
    By C Mesher in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2007, 15:24
  5. audi coupe 2.3 e cold start problems
    By buzby3xx in forum Classic Audi Forum
    Last Post: 27th August 2006, 23:21
