EM TuningVolks Autos
    GavinM's Avatar
    Nov 2004
    Falkirk
    10
    Question Audi A3 3.2 DSG Quattro S-Line - Rear Driver Side Shock Absorber 'Issue'
    On my Audi A3 3.2 Quattro S-Line (2005 05 registered, roughly at 93k miles now)... Ive recently heard a noise from the driver side rear wheel, most noticeable when entering the estate where I live where I slow down to about 15mph to navigate speed humps. Upon further inspection, Ive noticed what is best described as some sort of solid ring of carbon/concrete-appearing substance. The noise I hear occurs when I go over any sort of roadbump/sleeping policeman etc (as this part moves up and down the shock shaft).
    My questions on this are;
    1. is this dangerous ?
    2. is this expected over a lifetime of a shock ?
    3. will this have reduced the effectiveness of the shock/suspension ?
    4. should I get this immediately addressed ?
    5. if above is true, do i need to replace both rear shocks ?
    It is important to note that the car still drives fine, and the balance of the car still appears fine (given the age of the car). Im just concerned this is not meant to happen, and may cause further damage down the line...
    Some folks comment on this when I posted this in a forum I frequent far more often than here (a AV forum BTW), and they came up with the following points (hope they don't mind me copying wholesale here)
    1. Noisy rear shocks were very common on early A3s and modified shocks were made available for anyone complaining. The noise was best described as sounding like a rubber ball inside a plastic bottle. Perhaps yours missed the modified shocks, maybe it's just down to mileage. Personally, I wouldn't worry too much about replacing shocks in pairs if money is tight and only one is faulty.
      It's unlikely you'd notice any difference outside a race track. But if money isn't a problem, go for a pair. I also wouldn't necessarily bother with Audi shocks, I'd go for good quality aftermarket brands. No point paying Audi mark-up for something they've outsourced themselves!
    2. Looks like part of the bump stop.
    As a FYI, the other side rear shock looks like this
    Has anyone with a 2005/2006 A3 8P had this issue before, and did you go through dealer to get modified shocks, or would this be resolved by adding a bump stop, or go another way?
    Thoughts?
    A3 3.2 V6 S-Line DSG
    infernalzen's Avatar
    Feb 2012
    29
    looks like some bizzare material has built up on your gaiter +when the gaiter moves, it been rubbing against the arch
    can you remove the build up with a knife/pliers? trying not to damage the gaiter...
    Jun 2012
    Chester
    29
    I know this is an old post but did you sort this out I have had the same issue? To stop the knocking I've cut the metal off but need to know if i need to buy a new shocker or can I buy the mount?
    Has this happened to anyone else?
    May 2012
    perth scotland
    421
    They are bump stops nothing serious but can get highlighted at mot time they are cheap to replace just a rubbish job to do as you Jack the car up remove wheels so on and so on
    Audi a3 3.2 v6 sport back ,s-line, Dolphin Grey with factory tints, deg sat nav, bose speakers, 18 upgraded alloys, magnaflow exhaust, eibach pro kit springs
    Jun 2012
    Chester
    29
    The only problem is the plastic part that goes over the shocker is loose, I don't want the stuff off the roads going down there
  1. audi a6 2.7 tdi quattro s line
    By deebow in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th August 2010, 11:09
  2. Audi A3 2.0tdi 170 quattro s-line 2006
    By HIGGINS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2010, 15:45
  3. What's the final word with non DSG/quattro & S-Line?
    By schem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2005, 20:29
  4. 2004 AUDI A3 3.2 V6 Quattro S Line 3dr DSG on E-bay
    By lilya in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2005, 15:43
Tags for this Thread
