EM TuningAH Fabrications
    Jul 2012
    7
    Urgent help needed, Audi a3 2.0 tdi sline 2004
    Has any one had any problems when the car is at idle and its coughing/missing ,when cold but almost gets fine when car is fully warmed.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Common fault - First check your fuel filter doesn't need replacing, then find someone with VCDS & get them to check your tosion value (should be 0-0.5 degrees on the BKD engine).
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Jul 2012
    7
    Thanks mate going to check these now and let you know the results.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    check EGR
  1. Urgent Help needed with Audi 2.0FSI..
    By l33tgama in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2011, 00:42
  2. urgent help needed with my 2007 audi s3 please!!!
    By s3r4pid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2010, 18:30
  3. urgent help needed with my 2007 audi s3 please!!!
    Last Post: 14th December 2010, 10:09
  4. Urgent Help needed - How to replace air con pump on 2.0 tdi
    By m.lemon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 22:57
  5. Urgent help needed
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2003, 09:02
