Chris NottMonster Motorsport
Results 1 to 7 of 7
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    Air vents smelly particularly after turning air con off.
    Hi people hope someone could help! I've got a smelly old wet dog wiff coming through the vents particularly after the air con is switched off. I have checked to make sure no dog has worked itself into the air vents! Also i noticed the other night when i switched the car on the windscreen misted up for about 10 seconds then soon cleared.
    If the fans are off the smell is not there so it's definitely something to do with the vents, maybe mould in the ducts. I have tried the Comma air con cleaner from halfords. Works for about 2 week then the smell is back. I've also changed the pollen filter twice. It only smells in the summer months as well. Happened last year, Fine through winter. Now it's back again!
    Normally the smells I have encountered in cars is when the air con is ON and not when it is OFF which baffles me.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Get the air con serviced... That will debug it a removed bacteria in the system which is what you can smell. Also don't turn your air con off... It's designed to be on and let the climate regulate the temperature.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Jul 2011
    Bucks
    161
    as above and also change the cabin filter at the same time..
    Sportback owner
    Apr 2007
    France
    464
    Graham, there are two types of pollen filter for the A3. One is a normal panel filter made of paper, the other contains activated carbon. It is the activated carbon filter which should be used with an A3 with an aircon. All aircons produce water as a condensate from cooling warm and wet air. This water may help bacteria to grow within the system and cause smells. Using the activated carbon filter helps to eliminate the smells. Nothing wrong in cleaning the condenser/cooler matrix, but be sure you are using the right pollen filter as well. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    Thanks for the reply I was not aware of a carbon filter. I guess that's a Audi part? I've been using halfords pollen filters and got a can of the air con disinfectect that you spray down the vents. It's worked so far for a week.
    I'll definitely get a carbon filter if that's the correct one. Funnily enough the smells only started after I changed pollen filter for a non genuine.
    Sportback owner
    Apr 2007
    France
    464
    Graham, no the A3 filters (both types) are available from the filter manufacturers. I get my carbon version in France from a shop similar to Halfords. It was made by Valeo and is part number 7088091. Also fits the Golf V and Touran.
    Aug 2012
    Newcsatle
    7
    I Had this problem I was told to put air con on and turn heating on full when engine temp is @ max for about ten minutes this will kill any bugs in the system as the bugs will be killed @ temps over 82C. I did this a couple of times and it worked for me. no cost!!
  1. Climate Control Unit - Turn Air Con off? HI/LO display?
    By Poke13 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2011, 11:55
  2. Air vent Mounting bracket for NAVMAN icn520 sat nav
    By ravi in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 27th September 2005, 12:53
  3. Air vents???
    By unikarl in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2004, 14:43
  4. New A3 Air vents surrounds?
    By jasew in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2004, 19:01
  5. clicking noise from air vent???
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2004, 00:53
